My Omnitop 12's (Singles)
Re: My Omnitop 12's (Singles)
Those used to be the spec horn for DR's. I still have a couple laying around.
I have specs laying around somewhere. I'll see if I can find them.
Are these the asd horn drivers? and what woofer are you using? they look completely profesional, im hoping mine will turn out like this!!!
on the way:
OT12 x 6
T39 x 4
OT12 x 6
T39 x 4
The plans now call for a diffraction horn that you build yourself. If you go that route, use the NSD2005 and the 3012HO or 2512.Sleazy D wrote:Are these the asd horn drivers? and what woofer are you using? they look completely profesional, im hoping mine will turn out like this!!!
djtecthreat
Horns are Goldwood 500's, asd drivers.Sleazy D wrote:Are these the asd horn drivers? and what woofer are you using? they look completely profesional, im hoping mine will turn out like this!!!
I decided to use Beta 12A-II's.
And thanks for the compliments! Glad you like them.
DJ TecThreat
-Building-
8 More T48's
-Built-
4 SLA Pro's
-Building-
8 More T48's
-Built-
4 SLA Pro's
What mods(if any) did you make for the goldwood horn?
on the way:
OT12 x 6
T39 x 4
OT12 x 6
T39 x 4
djtecthreat
I think I just shaved 1/4" or 1/2" off each end of the horn to make it fit inside the OT12. Not a big deal, and the horn + driver is so light the 2 screws in the middle is more than enough to hold it in place.Sleazy D wrote:What mods(if any) did you make for the goldwood horn?
DJ TecThreat
-Building-
8 More T48's
-Built-
4 SLA Pro's
-Building-
8 More T48's
-Built-
4 SLA Pro's
If you want some I have a pair I'll sell cheap.
http://www.goldwoodsound.com/MidHorns.html
GM500pb at the bottom of the page.
I think I might take you up on that Leland, I'll probably pm you regarding that soon.
on the way:
OT12 x 6
T39 x 4
OT12 x 6
T39 x 4
And techthreat sorry for so many questions but I love these cabs... Haha did you just build the horn mount spec to the piezo array mount?
on the way:
OT12 x 6
T39 x 4
OT12 x 6
T39 x 4
djtecthreat
Missed this one, sorry it took so long to reply.
My horns are mounted with a couple pieces of 1x2" pine board mounted vertically. Nothing special.
DJ TecThreat
-Building-
8 More T48's
-Built-
4 SLA Pro's
-Building-
8 More T48's
-Built-
4 SLA Pro's
- camrynekai
So how did you like that gun?djtecthreat wrote:Thanks Seis!!
I forgot to mention, these are black Duratex spray grade shot from a wagner electric texture gun.
Facebook Page
More Bass then Fitzmaurice??? Click here
My herd of T48's
Cabs built
14- 24" T48's 3015LF's
6- OTop 2X12's W/Straight array's
4- OTop 12's W/melded array's
2- OTop 12's W/Straight array's
2- 29" Sla Pro's
1- Auto tuba ITW
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
djtecthreat
Its VERY messy but it gets the job DONE and FAST. You'll paint cabs in 3 minutes or less. In retrospect I wish I had rolled them, better control.
DJ TecThreat
-Building-
8 More T48's
-Built-
4 SLA Pro's
-Building-
8 More T48's
-Built-
4 SLA Pro's
- camrynekai
So you have rolled Duratex before what size roller did you use? I have the 4" roller and my OCD self just cant get it downdjtecthreat wrote:Its VERY messy but it gets the job DONE and FAST. You'll paint cabs in 3 minutes or less. In retrospect I wish I had rolled them, better control.
Facebook Page
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
- jswingchun
Why not get the cheapo harbor freight texture spray gun? It works well, and I assume you already have an air compressor.camrynekai wrote:...I just added 8 more cabs to my rig and cant swing Line-X pricing this year...was hoping to get close to the same texture using the Duratex
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
- camrynekai
The shop where I build @ has a compressor available but not much heat....so the 65 deg. minimum temp is gonna be tough to hit. I remembered those bigger hoppers when I did my popcorn ceiling...cant imagine using one of those bruits to do the Duratex or is there smaller one I'm not seeing?jswingchun wrote:Why not get the cheapo harbor freight texture spray gun? It works well, and I assume you already have an air compressor.
Facebook Page
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
