cutting circles with dremel?
is there an attachment for cutting circles with a dremel rotary tool?
Re: cutting circles with dremel?
There is, but I wouldn't use it for thicker than 1/4" plywood.greg wrote:is there an attachment for cutting circles with a dremel rotary tool?
+1
I tried it on 1/2" and it just ended up burning the wood.
Built: 2 T48 24" 3015LF, 2 DR250 2510
Planned: 4 T48 18" 3015LF, 4 DR250 2510
a $20 jig saw is a better bet probably not much more $$ than the atachment for the dremel
MADE
4- OT12'S BETAII
4 T39'S 20" 3012LF LOADED
ON THE BENCH: 2 OT212
MADE
4- OT12'S BETAII
- jswingchun
Or a cheap-ish router and a homemade circle jig.Israel wrote:a $20 jig saw is a better bet probably not much more $$ than the atachment for the dremel
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
I used a Dremel circle cutter to cut circles in 1/2" plywood. It works well and was faster than I expected. Just follow the directions and let the speed do the cutting.
DJ Nada wrote:I used a Dremel circle cutter to cut circles in 1/2" plywood. It works well and was faster than I expected. Just follow the directions and let the speed do the cutting.
+1 that's what I used to cut my Wedgehorn circles out and yes it was quite fast too.
Jose
BUILT
8 T48's 24" 3015LF LOADED
2 WEDGEHORN 10 MKIV's
1 SLA PRO FOR CENTRE FILL
Like us on facebook
https://www.facebook.com/Pulse.Entertainment.SA
Like us on facebook
