Tuba Time: T36 24" 3015lf
- Josh Sense
#1 was dropped off over the weekend. this thing is intimidating to look at, but not a big issue to move even for me being 5'4" 145lbs .
i don't want to risk any damage while i'm saving for DSP..
Hooked it up to one channel of a qsc rmx 2450 with the 30hz hpf engaged. used a 31 band eq to cut everything below 31.5 and above 100hz, set it up against the wall and even at super low levels i'm rattling stuff off the walls in my house. i can't wait to get to crank this one and it's future mates up.
Download my Dj Mixes: Soundcloud.com/joshsense
T36 24"W 3015LF
T36 24"W 3015LF
Re: Tuba Time: T36 24" 3015lf
Yeah, those subs Rock.
Try making your 31 band a mirror image of the response graph from the plans. This will help give you very even rich sound down there. Try it.
Pix, my man, pix. We're all into a little speaker porn.
T39 - Dual BP102 23"
AutoTuba
J12 x 2 - Deltalite 2512
O12 - Dual BP102
AutoTuba
O12 - Dual BP102
Where is that?...I didn't see that in the T30 plans.ewetho wrote:Yeah, those subs Rock.
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
- Russell Remley
Here is a pic b4 I delivered it. Just 2 coats of primer as he is gonna use bedliner on it himself.
- Josh Sense
playing some house and other stuff on her today.
- does get All The Way Down
but every track i've played so far - mainly house, and some hip hop. doesn't have very much at all below 40hz.
i haven't had the guts to try out some of my wonkier-stuff - like some old speed garage tunes yet in the house.
on the tops i'm currently using (club 15's) i'm cutting everything below 100hz on my graphic eq, and above 100 on the t36. my tops go down to 60hz supposedly, so i dunno.
T36 24"W 3015LF
T36 24"W 3015LF
That's not how you frequency assign. You must use an electronic crossover.Josh Sense wrote: on the tops i'm currently using (club 15's) i'm cutting everything below 100hz on my graphic eq, and above 100 on the t36.
- Josh Sense
yea, i know this. waiting for dsp :/ thats why i really haven't hooked it up for more than a few minutes or turned it up at all
T36 24"W 3015LF
T36 24"W 3015LF
Radian showed us that at our listening party. Try IT!!doncolga wrote:Where is that?...I didn't see that in the T30 plans.ewetho wrote:Yeah, those subs Rock.
You may really like it!
- Josh Sense
Bill Fitzmaurice wrote:That's not how you frequency assign. You must use an electronic crossover.Josh Sense wrote: on the tops i'm currently using (club 15's) i'm cutting everything below 100hz on my graphic eq, and above 100 on the t36.
technically speaking, can i get by doing some smaller gigs with just a typical 2 way/3way crossover, or do i need a limiter / dsp
T36 24"W 3015LF
T36 24"W 3015LF
- BrentEvans
Depends on how much risk you want to take. The sub horns don't complain like a direct radiator will... they'll just take more and more power until they go poof and work no more.Josh Sense wrote:Bill Fitzmaurice wrote:That's not how you frequency assign. You must use an electronic crossover.Josh Sense wrote: on the tops i'm currently using (club 15's) i'm cutting everything below 100hz on my graphic eq, and above 100 on the t36.
- subharmonic
If you are referring to the T36, it went like Crystal Clear Pepsi when the T60 came out.doncolga wrote: Where is that?...I didn't see that in the T30 plans.
I need more bass
CW Mcall
I need more bass
CW Mcall
- Josh Sense
studio monitors
its my 30th birthday
T36 24"W 3015LF
T36 24"W 3015LF
picked up mx882 + dcx2496. charles chase hooked me up with a sweet duratex job.
i resized the pic like 10 times and it says its too big so too bad for you guys
i finally got everything hooked up and time to actually turn it on without disturbing too many people. the dcx2496 is a beast, and for someone like me who has grown fond of turning knobs and pushing faders for the past 15 years, its challenging. i have a very basic setup running LH LH LH, output 1 goes to channel 1 of a RMX2450 to power the tuba. output 2 goes to the other side powering 2 x yamaha club 15"s. to start , i have the xover point set at 100hz. the yamaha's can go lower and are 'punchy' enough, so i am thinking about messing around with the settings a bit.
i have not gotten as far as the delay or deq.
more to come.
more to come.
- Attachments
- SST361.jpg (81.89 KiB) Viewed 3347 times
Build a pair (or 2) of DR250, and lose those heavy ass Yamaha Club IV 15's! I had a pair and got rid of them like a bad relationship. Just a pair of DR250s will kill those Yamaha's, 2 pair will just dominate. BTW, 2 DR250 will weigh close to the same as on of your Club 15.
