Turntable Isolation Solved
Monomer
Re: Turntable Isolation Solved
#16 Post by Monomer »
Carts are designed to operate best at certain tone arm weights.
You don't realize it, but over 5 grams of force of a diamond that's less then .010 is a SHITLOAD of psi.
The carts cantilever is designed to work best within a specific range. For M44-g's - I run 2 grams, for my NCE2's I run 3-3.5. Antiskate set to zero, depending on if it still actually works (most delicate part of a 1200) and tone arm slightly above level.
http://www.djforums.com/content/2007/04 ... roduction/ has plenty on proper turntable setup.
Oh, and it can actually skip MORE with the added tonearm weight. Adding weight to the headshell and then zeroing and setting proper tonearm weight maybe of help to you.
-More to come!
djslik
#17 Post by djslik »
You probably remember when scratch dj's used pennies or nickels to keep needles from skipping. I have never seen one skip more with one than without. Scratch DJ's used to go to greath lengths to get the perfect setup. I used to have problems until I changed needles. M44G's cured all my skipping issues with no extra modifcation to tonearm weight. So like I said try the needles first.
djslik
#18 Post by djslik »
On a side note...grab your Technics while you can suppliers are tapped dry and new tables are getting scarce. Used market should still be good though.
Monomer
#19 Post by Monomer »
djslik wrote:On a side note...grab your Technics while you can suppliers are tapped dry and new tables are getting scarce. Used market should still be good though.
always pdx's and ttx's on the new end.
used techs will be around forever.
-More to come!
Monomer
#20 Post by Monomer »
djslik wrote:You probably remember when scratch dj's used pennies or nickels to keep needles from skipping. I have never seen one skip more with one than without. Scratch DJ's used to go to greath lengths to get the perfect setup. I used to have problems until I changed needles. M44G's cured all my skipping issues with no extra modifcation to tonearm weight. So like I said try the needles first.
Shure's also sound terrible.
I always gig/record with NC-E's.
Then again, I do almost no scratching
-More to come!
djslik
#21 Post by djslik »
Haha I can't comment on the sound quality but most Scratch DJ's don't care, it was how well it tracked that mattered. With Serato sound quality is a moot point.
Just mentioning the Technics if it holds any sentimental value as it does for me. My tables from 1995 are still gigging with me today.
nastyford77
#22 Post by nastyford77 »
I can't even remember which carts I'm using, but i know they are cheaper. I'm running 3.5 grams weight, 0 skate, level tonearm. My idea with isolation was cheaper than buying 2 more carts. It's not too big of a deal for me, mainly because I don't scratch too often. If I was a heavy scratcher, I would definately have to upgrade carts.
DJ 4CE
