Introducing SPL Chart
Mikey
Re: Introducing SPL Chart
#151 Post by Mikey »
Thank You, Chris!
Just one observation ... T30W27D3012LFC2 ... that didn't look right to me so I went to the SPL charts section ... that's not two cabs, it's two 3012LFs in a single 27"w T30.
Albert Einstein
#152 Post by Chris_Allen »
Mikey wrote:Just one observation ... T30W27D3012LFC2 ... that didn't look right to me so I went to the SPL charts section ... that's not two cabs, it's two 3012LFs in a single 27"w T30.
I pondered that for a while but concluded that you couldn't get that much gain with the same mouth area. I'll get it changed.
#153 Post by Chris_Allen »
Just wanted to highlight that there are charts of the DR's that are ported and unported. All those with the compression drivers are ported. Also, the original DR200, DR250 and DR280 will be unfiltered and have the original curved horn.
#154 Post by Chris_Allen »
The new Jack 115:
Code: Select all
[spl]J115D2515,J115D2515M20,J115D2515ASD1001,J115D2515NSD2005&dbmin=80[/spl]
#155 Post by Chris_Allen »
J115 against the OmniTop15:
Code: Select all
[spl]J115D2515M20,OT15P20M&dbmin=80[/spl]
CafSentryGnome
#156 Post by CafSentryGnome »
which chart is right? this one is different
#157 Post by Bill Fitzmaurice »
Read the fine print on his OTop chart.
#158 Post by Chris_Allen »
I'll verify against the latest plans, the OT15 was one of the first charts.
Yeah, as Bill says, I obsoleted it. Was replaced with this one:
Code: Select all
[spl]OT15M20,J115D2515M20&dbmin=80[/spl]
My mistake with the previous post - I've updated the first page.
#159 Post by Chris_Allen »
The new Omni 12 and Omni 15's with lower crossover frequency, different mid horn, phase plug and APT80 HF driver:
Code: Select all
[spl]O12D2512DA6AAPT80,O12DBP102X2DA6AAPT80&dbmin=80[/spl]
Code: Select all
[spl dbmin=80]O15D2515DA6AAPT80,O15DD12LFX2DA6AAPT80&dbmin=80[/spl]
Sorry for the long names!
Mark Coward
#160 Post by Mark Coward »
Which LF driver was used in the DR280 for this chart?
Mark Coward
#161 Post by Chris_Allen »
It came from the latest plans, so I would say the 2512
Mikey
#162 Post by Mikey »
Chris, would you please add the 24"w 3012LF T39? It's in the SPL charts section ...
http://billfitzmaurice.info/forum/viewt ... f=12&t=487
Thank You!!!
Albert Einstein
#163 Post by Chris_Allen »
Mikey wrote:Chris, would you please add the 24"w 3012LF T39? It's in the SPL charts section ...
Thank You!!!
Here are all the multiples on 24" wide T39's:
Code: Select all
[spl]T39W24D3012LF,T39W24D3012LFC2,T39W24D3012LFC4,T39W24D3012LFC8&dbmin=85&fmax=200[/spl]
#164 Post by Chris_Allen »
Here are the new OmniTop 12's with the phase plug:
Code: Select all
[spl]OT12D2512M12,OT12D2512ASD1001,OT12D3012NSD2005&dbmin=80[/spl]
I need to double check the sampling range on the NSD version.
Mikey
#165 Post by Mikey »
Thank You, Chris!
Albert Einstein
