Carver Amp Capacitor Bolt Missing
Is this amp OK?
doncolga
#1 Post by doncolga »
Hey,
I've got a Carver PM 950 Power Amp and a bolt on one of the capacitors (I think) has come loose. I've gotten the bolt out and the unit powers up fine. Does this need immediate attention or can I still play with this? I've included a picture. Clearly, it's in a very tricky spot to screw back in. I was going to try running my old EV boxes for tops so I can go ahead and sell my SRM 450's to fund my Otop 12's. I'm so tired of running damn power and audio cables to those things...very cluttery! :wall:
Thanks!
Donny
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
camrynekai
Re: Carver Amp Capacitor Bolt Missing
#2 Post by camrynekai »
Oh yes, put it back in before you use the amp again...just be careful in doing so...the caps may still have a charge on them :shock:
Facebook Page
More Bass then Fitzmaurice??? Click here
My herd of T48's
Cabs built
14- 24" T48's 3015LF's
6- OTop 2X12's W/Straight array's
4- OTop 12's W/melded array's
2- OTop 12's W/Straight array's
2- 29" Sla Pro's
1- Auto tuba ITW
doncolga
#3 Post by doncolga »
camrynekai wrote:Oh yes, put it back in before you use the amp again...just be careful in doing so...the caps may still have a charge on them :shock:
Yes...I've discovered that...and they did! :oops:
Donny Collins
Drey Chennells
#4 Post by Drey Chennells »
:idea: DOH!
...well next time discharge those caps into a resistor or by shorting the + to - , or the + to the chassis.. use a value of somewhere between 10K and 100K. The larger the value of the resistor, the longer it will take to discharge the caps, and the less of a spark youll see. As the handy chart below shows you the relationship between rc value, charge and discharge time.
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
