Bruce Weldy wrote:
You should sum the L and R output of the mixer by making a Y cable so that both signals come out of one connector in mono. Either that, or just run the left or right side and pan every channel that way. Y is better.
No no no. When you make a y cable what you're doing is driving one input into the other. Is it not AT ALL like splitting where one output is driving both inputs. If you must combine, a direct box or a "mixer" must be used, not a y cable. Y's are for splitting, not combining.
Bruce Weldy wrote:
On the amp speaker outputs - Don't run one jack off the Speakon and one on bannana plug. Just run from the Speakon to the first Jack, then daisy chain to the other one (use the parallel speakon jack on the speaker to run to the other speaker).
Why not? The down side here is that the first will get slightly more power than the second as the second cable will be piggy backed onto the first and adding further resistance. It's doable and it really won't be all that noticeable, but just to keep everything optimal, splitting right from the amp is best. If you cannot, then don't sweat it. Since this is how I run my set up most of the time, I actually built a speak-on splitter from some jacks and a little project box from mcm. Works perfectly when I don't want to use banana plugs as the powered mixer does not have them. The other plus side of splitting right from the amp is that your wires can be shorter if you place your amp in the middle. The real down side, though, is having to deal with banana
As I do not have a dcx, someone else will have to chime in, but if you can combine the stereo inputs with the dcx then the way you have your diagram is perfect. However, if you cannot, once you send a signal to the R input, it will make everything stereo, so everything on the Right channel will not be played if the dcx does not combine. If this is the case, then you must combine outside.
What are you using as far gear to kind of get an idea how it will be good to combine if the dcx cannot do it?
