info
Is this amp OK?
jesuchete
info
#1 Post by jesuchete »
I was looking at dr200 spec sheet. I noticed that 8 dr200 would do a good job for our smaller crowds of about 1500 to 2000. Intend to have about 12t39 to go with these. What would be recommended amps for this set up. I am using yamaha amps.
Israel
Re: info
#2 Post by Israel »
i havent read the dr200 plans but i though that its power limit is about 100w :feedback: 12 t39 will suffice giving to them about the same 100w per cab so wee are talking about 800w total power for the drs and 1200w maybe a little more for the subs
MADE
4- OT12'S BETAII
4 T39'S 20" 3012LF LOADED
ON THE BENCH: 2 OT212
jesuchete
Re: info
#3 Post by jesuchete »
how many sheets of plywood would I need for a Dr200?
Doug Hart
Re: info
#4 Post by Doug Hart »
One sheet of 1/2".
Plus you'll need some 1/4" and 1/8"
Doug Hart, Owner
dB Pro Audio
Authorized Builder
http://www.hartdesignsetc.com
jesuchete
Re: info
#5 Post by jesuchete »
Thanks that puts them a lot cheaper than the Dr300. I am paying close to $60.00 for the 1/2 inch stuff from the home depot. Can`t seem to find any where cheaper here in kitchener Canada.HD claims its the real deal.
slyslam
Re: info
#6 Post by slyslam »
jesuchete wrote:Thanks that puts them a lot cheaper than the Dr300. I am paying close to $60.00 for the 1/2 inch stuff from the home depot. Can`t seem to find any where cheaper here in kitchener Canada.HD claims its the real deal.
I paid around 35$Can. for Arauco and the Russian Birch sells for 40$ in the Montreal area. I would look with a different supplier. Do you have any Lowe's in your area?
jesuchete
Re: info
#7 Post by jesuchete »
the nearest lowes is in Burlington Ont. I am in kitchener so its quite a drive. I suppose its worth the trip if i am buying in bulk.
Re: info
#8 Post by Tom Smit »
I just searched and found these....
http://jwsdecks.com/jwswoodworking/contact-us
http://kwartzlab.net/blog/robert-gissin ... loo-region
The stuff and HD might be BB but it likely has a very thin veneer, so thin that you might need a magnifying glass. If it is, you might be able to lift it with your finger nail....which would prove that is not the stuff you want. Happy hunting!
Scott Brochu
Re: info
#9 Post by Scott Brochu »
Tom Smit wrote:I just searched and found these....
^^I second that, HD will try to sell you birch ply wood but it is not BB (could be wrong in your neck of the woods though).
I would at least closely inspect the plys like Tom Smit says.
You must have a local cabinet maker in you area. Check with him and he might be able to land you a deal on real BB or help you out in finding some. Instead of going to Tim buck two yourself to get some. :mrgreen:
Drumming is a way of life.
ME LIKE TO HIT THINGS!
Re: info
#10 Post by DJPhatman »
jesuchete wrote:I was looking at Dr200 spec sheet. I noticed that 8 Dr200 would do a good job for our smaller crowds of about 1500 to 2000. Intend to have about 12 T39 to go with these. What would be recommended amps for this set up. I am using yamaha amps.
Use the 16 Ohm DeltaPro 8 and you can run the whole system from 2 amp channels running @ 4 Ohms. A single Crown XTi4000 fits the bill perfectly. But, if you have a Yamaha amp that does 900-1000 Watts @ 4 Ohms, then you are golden.
T_Gowan
Re: info
#11 Post by T_Gowan »
Commonwealth Plywood
100 Randall Drive
Waterloo, Ontario
N2J 4A9
(519) 885-2810
This is the real deal , not sure if their prices are better or worse, changes with the market,
I haven't seen anything in HD that I would call BB, maybe at times in the small handy panel sizes but not full sheets,
These will be 5x5,maybe 4x8 sheets at Commonwealth, be sure to ask for Russian Birch or Baltic Birch
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
T_Gowan
Re: info
#12 Post by T_Gowan »
I have built some Dr200 x2 and T24 16" pair
Would love to hear T39s when you get them working,
TG
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
Re: info
#13 Post by Tom Smit »
T_Gowan, thanks for that! I found Commonwealth Plywood in London, On ...so I'll have to check them out some time.
