2 24" T48 build (my first build)
djeccentric
Re: 2 24" T48 build (my first build)
#16 Post by djeccentric »
i have some more pictures of my progress over the past few days. i am getting so close i can hear/feel it.
a nice look at the 1/8 corner with the qurter round behind the handle holes. i think they are going to feel pretty nice once i round the corner over ( i am using 3/8 radius due to the cab corners i am using)
speakon mount plate i thought it would be worth the money for the simplicity and professional look.
the hole for the speaker wire.
("edit" ha ha i posted the same one twice) this is the wire i will use a thin insulation 12 gauge i picked up from the half off bin at lows i got two 22' bundles for like 5 bucks.
and the pile dwindles down.
djtrumptight
#17 Post by djtrumptight »
I wish i had caught this post b4 u cut the handles,they are more comfortable (to me) when they are 1/2 inch from the edge.Plus,keep in mind that the back panel is actually about a 1/2 inch shorter than the side panels so hopefully u took that into account when u cut the bottom hand holds.Also,i cant really tell but you seem to have areas that arent getting adhesive squeeze out which could lead to leaks,such as the area around the driver spacer ring as well as the bottom of the driver chamber.
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
djeccentric
#18 Post by djeccentric »
alot of places i would wipe the squeeze out into a nice bead after i tacked the piece in with the nail gun. i did notice the lack of squeeze out on the chamber reducer and put a nice bead along it. as for the handles i did compensate for the half inch difference
ewetho
#19 Post by ewetho »
After building 4 with baronvonsteve this summer, keep up the nice work. Those are going to Jam!
djeccentric
#20 Post by djeccentric »
so this is a little off topic but who here believes in ghosts. in one of the two pictures in this post you can clearly see an orb. or for the skeptics what looks like what they call an orb on those ghost hunter shows. i am not claiming anything here but when i noticed the orbs i definitely had an oh shit moment.
thesoundmechanic
#21 Post by thesoundmechanic »
Looks like there are about 4 "orbs" in the top picture and 2 that I can see in the second pic. I'm not sure about orbs, sawdust can create some of those blurry spots. I also believe in ghosts, they tend to piss me off. :chainsaw: I wish they could materialize for a few minutes so we's can have us a fist fight to end the ol' haunting game. :bash: :loler:
Gauss
#22 Post by Gauss »
I find stories of ghosts (and how people pull explanations out of the air) interesting, but usually just designed for attention (e.g. Amityville's hoax for movie publicity) or the fun of scaring people.I'm not saying there is nothing out there, I have read about the seven sons of Sceva who were "exorcists" until they came upon something real, so there is something. I took photography and those "orbs" are nothing supernatural, just circles of confusion ( http://en.wikipedia.org/wiki/Circle_of_confusion ) - in short, lens limitations.
BASS: Combo Amp & Titan39
djeccentric wrote:so this is a little off topic but who here believes in ghosts. in one of the two pictures in this post you can clearly see an orb.
Dust on the lens.
jcmbowman
#24 Post by jcmbowman »
Dust on the lens.
Great, now I've got Kansas stuck in my head.
"Dust on the Leeeeeeeeeeens,
All we are is dust on the lens."
4 DR250s
4 Tuba36s @ 30" wide
2 ATs
tdogg
#25 Post by tdogg »
djeccentric wrote: Image
did you add a partition in the driver chamber? :confused:
Jack 112 deltalite 2512 x2
#26 Post by Bruce Weldy »
Relax, it's in the plans as an option.
tdogg
#27 Post by tdogg »
hmm i missed that (looking for it now), as im working on my first t-39 right now. what does it do?
tdogg
#28 Post by tdogg »
nevermind i just realized that the option is only offered on the t48 :bash: :fruit: , not the t39. any reason that this couldnt be done on a t39? not that i would, just curious.
djtrumptight
#29 Post by djtrumptight »
Back to the topic,dude,if i was you,i would go back and add PL to all those braces,all around the driver spacer ring,everywhere where u have joined 2 pieces of wood because from what i see you are gonna get some rattling.The object is not to smooth the PL,but to let it expand and seal the cab air tight and that doesnt look air tight to me.Once you add that last side panel,its over,there is no way to get to some of those braces.I had to take my driver back out of one of my T48's and add PL all around the driver spacer ring,inside and outside and the braces in front of the driver,i think it would be easier to do it before sealing it up than after.Otherwise from what i see :horse:
2 SLA HT systems
2 SLA Pro's
djeccentric
#30 Post by djeccentric »
