Defective DRPA
Defective DRPA
I purchased a DRPA on eBay a couple years ago (used, of course). It is now acting up on me. The readout screen is all garbled making it effectively useless. It seems to me that this was a known problem? Does anyone know if there is an easy, cost effective fix? I was gonna contact DBX, but I thought I'd ask here first.
- Dave Non-Zero
Re: Defective DRPA
I've had that happen a couple of times on startup with mine. It seems to be a screen thing, as it works fine if you are using the same setting as the last time. I've found a bit of percussive maintenance works too. (um, hitting it) then switching it off and on again.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
Re: Defective DRPA
Mine was messed up looking out of the box new! It wasn't until I turned down the brightness of the screen that it got clear again. It was on it's highest setting when I first turned it on and very hard to read and garbled looking for sure.Ron P wrote:I purchased a DRPA on eBay a couple years ago (used, of course). It is now acting up on me. The readout screen is all garbled making it effectively useless. It seems to me that this was a known problem? Does anyone know if there is an easy, cost effective fix? I was gonna contact DBX, but I thought I'd ask here first.
2-Otop 12 W/3012HO and 12 tweet Melded Arrays
2-20" Titan 39 W/3012LF
2-Jack 1x12 W/3012 HO
