Liquid Tape for...
DanielNY
Liquid Tape for...
#1 Post by DanielNY »
Here is one stop solution for sealing piezos and also giving a protective coat to those bare wires when your done wiring those arrays.
http://www.grainger.com/Grainger/items/1MPY3
I used this stuff on my melded arrays to seal the assembly and also insulate the bare wire once I was done wiring/soldering. This is similar to plasti-dip but its a brush on version and it is liquid enough to get into all those little spaces/ it also dry's with good time. It bonds to metal and plastic alike and can't be rubbed off like rubber cement. I used black which also gives your arrays a nice finished look on the backs as well.
I found this stuff available at an auto-parts store and one can will cover a full array, maybe even two. Give it a try you wont regret it. It works so well you better be sure your 100% before you seal everything.
David Carter
Re: Liquid Tape for...
#2 Post by David Carter »
Great idea! Next time I have to build a melded array, I'll definitely check it out.
Dave
- 2 x Titan 39 (BP102 - 14"W)
Drey Chennells
#3 Post by Drey Chennells »
cool Ill try some,thanks. fwiw I've used pvc glue for 2 arrays now, doing 1 row at a time, finished with black acrylic paint brushed on,piezos attached. very seamless. I intend to wire up with 22 gauge solid copper,and rattle can the entire backside..
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
#4 Post by DJPhatman »
For those that have a Harbor Freight Tools near them, they carry brush-on and a spray-on version. Prices vary as does availability, but should be much cheaper than Grainger's.
DanielNY
#5 Post by DanielNY »
DJPhatman wrote:For those that have a Harbor Freight Tools near them, they carry brush-on and a spray-on version. Prices vary as does availability, but should be much cheaper than Grainger's.
I didn't realize there was a spray on version, this stuff is awesome.
DanielNY
#6 Post by DanielNY »
I picked up White liquid tape from home depot for $5.49. The white on black contrast will make it easy to see any holes or spots that didnt get sealed peoperly.
