Finish nail gun
sine143
Finish nail gun
#1 Post by sine143 »
Have to say, this thing is soooo much better than drilling pilot holes and throwing drywall screws into the cab. Just tried these out on the otop build, things are going nicely thus far.
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
Scott Brochu
Re: Finish nail gun
#2 Post by Scott Brochu »
also makes filling in the holes a lot easier. :mrgreen:
What kind did you get?
Drumming is a way of life.
ME LIKE TO HIT THINGS!
sine143
Re: Finish nail gun
#3 Post by sine143 »
I'm home for spring break (Read: I have access to my table saw, good Router, Drill press, and all my other tools).
Dont even know the brand of it, but it seems to do the trick.
1x bastard XF208
Re: Finish nail gun
#4 Post by Bill Fitzmaurice »
It's also the greatest thing to install room carpet if yours will do 1/4" crown staples. I hate installing carpet, but staples make it fast and easy, and the carpet nap hides the installation. Also use staples on DR builds for the bent panels, as brads just tear through 1/4 and 1/8 inch plywood.
sine143
Re: Finish nail gun
#5 Post by sine143 »
I was highly considering building the dr 200, but instead opted for the omnitop, cause I I dont have a quick line on bendy ply, and I'm only going to be home with my tools or a short period, which may have kept me from finishing the tough DRs.
Perhaps the next bfm system I build, If I decide to part ways with this one will be a DR/Titan combo, rather than a T30/OTop12 combo. Only time, and money will tell I guess.
1x bastard XF208
Scott Brochu
Re: Finish nail gun
#6 Post by Scott Brochu »
sine143 wrote:I was highly considering building the dr 200, but instead opted for the omnitop, cause I I dont have a quick line on bendy ply,
I don't either, that's why I got to call around and do some leg work. :mrgreen:
SoundInMotionDJ
Re: Finish nail gun
#7 Post by SoundInMotionDJ »
Bill Fitzmaurice wrote:Also use staples on DR builds for the bent panels, as brads just tear through 1/4 and 1/8 inch plywood.
+1
I only used 1/4"x3/4" staples on the bent parts of my DR's. It took a couple of shots to get the pressure set correctly...but after that it worked like a champ.
--Stan Graves
10 T39S + 10 DR200 + 1 T48
Israel
Re: Finish nail gun
#8 Post by Israel »
since baltic birch can not be found here I chnged to woodworking plywood....... also I preffer staples than brads for strenght (so the glue holds better) To hide the staples I first fill the hole with regular woodworking glue (gently with my finger) then sand. the glue fills the hole the sand dust does the finish pretty neat great for those clear barnished table tubas of the photos
MADE
4- OT12'S BETAII
4 T39'S 20" 3012LF LOADED
ON THE BENCH: 2 OT212
djwoo
Re: Finish nail gun
#9 Post by djwoo »
Bill Fitzmaurice wrote:It's also the greatest thing to install room carpet if yours will do 1/4" crown staples. I hate installing carpet, but staples make it fast and easy, and the carpet nap hides the installation. Also use staples on DR builds for the bent panels, as brads just tear through 1/4 and 1/8 inch plywood.
I want to carpet my T39, they are now naked but I really hate the yellow contact glue, if I do the carpeting with a stapler Can I avoid the glue? or I going to need some?
¿TEQUILA?...
David Carter
Re: Finish nail gun
#10 Post by David Carter »
If you only staple the carpet, I don't think you'll like the results. It will stretch over time and not stay tight. It will also rip and tear more easily than if it is glued down. Glue is messy, but will provide a better result. Do you have access to spray-on adhesive like 3M Super77?
Dave
- 2 x Titan 39 (BP102 - 14"W)
djwoo
Re: Finish nail gun
#11 Post by djwoo »
Yes, but at $ 22.00 usd per can it's pricey for me. I make with the contact but only in certain parts (corners, center) and staples in the rest
¿TEQUILA?...
David Carter
Re: Finish nail gun
#12 Post by David Carter »
djwoo wrote:
David Carter wrote:you only staple the carpet, I don't think you'll like the results. It will stretch over time and not stay tight. It will also rip and tear more easily than if it is glued down. Glue is messy, but will provide a better result. Do you have access to spray-on adhesive like 3M Super77?
Let us know how it turns out. :)
Dave
coremaster
Re: Finish nail gun
#13 Post by coremaster »
The 1/4" size of a crown staple fits to the carpet. Staples are used for installing carpets. You will just pull the trigger to staple the carpet.
Re: Finish nail gun
I said room carpet, not cab covering.
