What does 10" drill press mean?
I thought it meant 10" of clearance. I bought one and there's about 7" without the bit. With the bit, I can't fit my DR assembly in it to drill out the speaker mount holes. Grrr.
Re: What does 10" drill press mean?
10" from the center of the chuck to the post.
That's what I get when I don't do the least amount of research before a purchase
. I got a little frustrated initially, but I can make it work, just have to make sure the driver hole punches are in a certain spot.
A 10" drill press just means there's 10 inches from the support post to the center of the drill chuck. It doesn't mean anything about the depth it can drill.
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
Dang, went to change a stinky diaper and Bill's already on it
Bobby Shively
