Mostly Melded Array Review HT-DR165
WB
Re: Mostly Melded Array Review HT-DR165
#16 Post by WB »
dave d wrote: why they are called the DR165? Thanks!
They're scaled down DR200's.
J_Dunavin
#17 Post by J_Dunavin »
you can do that?? With what driver?
#18 Post by Chris_Allen »
165mm driver - 6.5". Same naming convention as the DR200/250/280
dave d
#19 Post by dave d »
How much smaller are they?
Thanks for the info!
WB
#20 Post by WB »
dave d wrote: How much smaller are they?
13.5"H, 14"W, 13.5"D
oilcanracer
#21 Post by oilcanracer »
do they lose the bottom hz's or is the spl the same just lower volume?
#22 Post by Bill Fitzmaurice »
oilcanracer wrote:do they lose the bottom hz's or is the spl the same just lower volume?
When you scale a horn down you get less low end. IMO the DR200 is a small as you should go with the DR design.
oilcanracer
#23 Post by oilcanracer »
wow i didn't realize how small they are. its like building doll furniture. maybe good practice to learn how to build different models, but not invest in plywood costs.
how about a super mini subwoofer.
#24 Post by AntonZ »
You need a long horn and mouth surface area to go low, there's no way around that. T18 and AT is about as small as it goes. If you want to go smaller, build direct radiators, ported or bandpass.
CafSentryGnome
#25 Post by CafSentryGnome »
iPod speaker dock anyone?
GeSo
#26 Post by GeSo »
These Dr165 & 150 have always been a puzzle to me. All this time I was thinking it was the amount of 1060's that were being used. Are there plans forthese speakers? I wouls love to pull the trigger and have a pair of 200 and 165 or 150's in my theater. The 200's would be too big (physical size) for the rear, the 165's would work. I see above Bill is against anything smaller then the 200's but I think they would do a good job as rears? :fingers:
mudbwetdirt
#27 Post by mudbwetdirt »
GeSo,
They are okay for rears but like Bill said they have no bottom end. I took the DR200 measurements times .81 to get the DR165 size. If there is any way to squeeze the DR200 in, it would be much better.
Mud
My Name Is Mud B. Wetdirt it's been Mud for as long as I can remember. She has other names for me but I can't use them on family forums.
Tsloms
#28 Post by Tsloms »
Which woofer is being used in these? Do you have any measurements?
#29 Post by Bill Fitzmaurice »
GeSo wrote: for the rear, the 165's would work. I see above Bill is against anything smaller then the 200's but I think they would do a good job as rears? :fingers:
IMO the DR200 is as small as that design should be built. If you need a smaller cab make it a direct radiator, you'll get a better result. If you don't need a cab as large as the DR200 you don't need a DR.
