6 x WH8 MkIV build. 3 x Completed.
Re: 3 x WH8 build.
#76 Post by Grant Bunter » Sun Jun 07, 2015 5:03 pm
heavybdrums wrote: Thanks sooo much for posting and linking your build thread for us. I am in the process of building 2 wh 8's with the delta pro 8a drivers and also would like to paint the tweeter arrays. How did you prepare them for painting?(do you have to remove the elements from the back to do this ?).
No worries.
Yes, to paint the piezo's, remove the screws from the back and carefully remove the back and the element. Set them aside somewhere safe while you paint. I used rattle tins to paint mine.
I recommend to remove the screws by hand (ie with a screwdriver) and put them back in the same way. You don't want to strip the piezo bodies. Don't ask me how I found that out!
heavybdrums wrote:also a newbie question about forums here: i am having problems posting pictures on here, when i try to it says the image is too large to post. How can i get pictures to post on here ?
Just to show you, hit the quote button on your reply above this post.
You'll see links to my photobucket account for the image. That's how I put up images.
You can upload images directly to the forum, but the pics have to be the right size.
Not a problem with photobucket.
Upload to photobucket, upload, go to the pic, right click the [IMG] line (should say "copied"), then paste.
heavybdrums wrote:Curious about the grille material, is it just hardware store bought expanded metal?
We're not as fortunate here in Australia, we don't get such items at our local hardware.
Mine was ordered from the manufacturer via a reseller. I bought an 8 x 4 sheet.
Yes, it's expanded aluminium, the aluminium itself about 1.6mm (roughly 1/16") thick. I got the non flattened style, it cost less.
Any Aussies wanting to get the same material, the manufacturer is the Lockyer group and this is the 12/20 product IIRC...
T39's: 4 x 20" BP102 , 2 x 28" 3012lf.
WH8: x 3 with melded array.
heavybdrums
Re: 3 x WH8 MkIV build. Completed.
#77 Post by heavybdrums » Sun Jun 07, 2015 7:48 pm
so in Australia you call them rattle tins..I like it, here we call them spray bombs or spray cans in Virginia. Spray bombs due to what they do when put in fire..lol. Thanks again for all the info. Now that i know how to post pictures, some coming soon.
4x WH8 delta pro
2x WH10 Deltalite 2510
4x Dr250 Deltalite II 2510
8X Titan 39 3012lf, 28"
4X Tuba 60 W/ lab 15
#78 Post by Grant Bunter » Mon Mar 30, 2020 3:02 pm
Updated, replaced photobucket hosted pics wherever possible...
Re: 6 x WH8 MkIV build. 3 x Completed.
#79 Post by Grant Bunter » Fri Jun 11, 2021 3:48 am
Well, here we go again.
3 was enough way back when, but I'm doing more, with increased foldback requirements at times (sends and consequently cab count), but not enough cabs.
Today, began cutting up ply for 3 more.
Drivers sourced/purchased (Beta 8A). Small interlocking Penn Elcom corners sourced in Australia.
Right now, shipping, import charges and the time it's taking for orders to arrive from overseas are not representing any significant savings at all.
Over the last couple of years I've managed to get some trade accounts. One, an electronics supplier, covers Neutrik, Dayton amongst other things, including Daichi 1016's. Pretty much identical to Goldwoods, but 3K instead of 3.5K for the goldwoods, and up.
Same prices, or better, and local shipping.
So, everything is going to be sourced in Australia (except PL damn it, lucky I have enough).
Sorry Leland.
I was thinking 5, but that's stretching the budget a bit for now.
Stay tuned...
