Last night I glued the braces onto the back of my first Jack and cut the hole for the connector dish and so, as soon as I finished work today I fired up the soldering iron, wired up the speakon connectors and brought the cab in from the workshop.
20 minutes later the driver was clamped into place, the back held on with 4 screws and the plate held on with two and ready for the first test. I connected everything up and slowly brought up the volume.
First impression was that it was very clear right through the range. Top end was good (I won't require a HF section for my style of playing) and very strong below 50Hz. I then switched the cable into my existing cab, a Warwick 15inch which I upgraded with an Eminence 3015. This sounded slightly louder and with a bigger rounder sound. I plugged the Jack back in and stepped further away. I noticed a difference which seemed strange, the sound seemed to get 'bigger' without being louder. (I hope that conveys something meaningful to you all because I find it hard to use words to describe sound). By this time I was being verbally abused by wife and daughter but before I shut everything down I asked my wife to listen to the Jack and then the Warwick.
I asked if the Warwick was louder. "No, it sounds muddy" was the response.
When I first came to this site I tried to maintain a level of scepticism, lets face it, if you build something for yourself you want to believe its good, but the fact that professionals build herds of these cabs and use them week in week out when their sound is their reputation convinced me to have a go. I'm so glad I did, the little 10" Jack is dwarfed by the Warwick but compares well. When you consider that the cab is as yet unlined and is certainly not airtight with just 4 screws holding the back on and the speaker isn't fully broken in yet, then things can only get better.
And there's another set of panels already cut and another DLII 2510 waiting to be used.
Thanks Bill for the design and thanks to all on the forum for help and inspiration. Now I have to try to contain my patience and not rush the finishing of the cab.
