Are there other suggested amps like the XTI series
That don't have the DSP? If I have a DCX2496, I don't really need to pay the "extra" that may be included in the price of the XTI, but I'd love the weight (or weightlessness in this case!) of those amps.
Is there anything comparable out there? I think the verdict is still out on the Behringer EPX series...?
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
- David Carter
Re: Are there other suggested amps like the XTI series
QSC's PLX2 series are very good lightweight amps. I had the PLX1104 for a while, and it weighed in at 13 lbs. Only thing to watch out for is the model numbers ending in "04" can only do 4 ohms. QSC's GX series is cheaper and just a little heavier. Peavey's got a new IPR series (I think that's right) that's supposed to be lightweight. They have models with DSP and models without it.
The only one of the above that I can vouch for personally is the QSC PLX2 series. I was very pleased. I only sold it to finance a Crown XTi 4000 that I got a great deal on.
Dave
- 2 x Titan 39 (BP102 - 14"W)
I saw those PLX series, but they're a good bit MORE than XTis (weird)!
I'm just so skeptical when it comes to the XTis because of all the reviews/complaints I've read online about them failing during gigs. The point of this is to reduce weight for me, not carry two backup amps in my rack
The Powertech is like 35 lbs, and that Microtech is another 40, I think. Back breaking.
I'll have to look into those GX amps. Which one should I be looking at if I want to run it mono with the T48s on one side and DR200 on the other? GX5?
Bobby Shively
- David Carter
Check out the QSC GX series and see if it seems like it will meet your needs from a weight and price standpoint. I've never used one, but I've never seen anyone complain about them either.
Dave
wallywally
Just remember most of the time people only sound off when they have a problem. The XTi's did have some issues early in production with ribbon cables and the display board. From what i've read those problems have been resolved. Crown claims the failure rate is 1.5%. I have owned 2 xti's for about 1.5 years and they have been good. On 1 of them I did have to reload the firmware because it wouldn't always boot correctly. The only other complaint I have is they do hiss(slightly). Overall I am very happy with the XTi's and I wouldn't hesitate to buy them again. As far as price goes I haven't seen any lightweight amps that cost less yet.
Builds:
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
- David Carter
I have noticed this also with my XTi 4000. My QSC PLX1104 wasn't dead silent, but it was noticeably quieter than the XTi. However, for pro audio, it's a moot point. As soom as you put even a minimal signal level through it, the slight hiss is overpowered by the source material.wallywally wrote:The only other complaint I have is they do hiss(slightly).
Dave
sstillwell
A big thumbs up for the PLX2 amps. I run an 1804 on the tops and a 3602 on the subs...with another 3602 sitting in the wings for when I get REALLY crazy. They thump HARD. I've got XTi's too...using a 4000 for monitors, and another 4000 and 2000 in a "B" rig. Tried 'em both...preferred the QSC.
Either way, you can't beat the weight...beats the heck out of my 80lb Hill DX3000...I still have nightmares about carrying that thing.
If we were talking about Itech or Macrotech .vs. full-on Powerlight I might come down on the Crown side of things...but maybe not.
Scott
Scott
The new Peaveys look interesting, available both with and without DSP.
Dazombiewoof
+1 for Peavey. Usually very good price point and reliable. I also own a PLX2 1804 I use for a bass rig. Nothing succeeds like excess.
"Telling you all the zombie truth, here I'm is....."
Went ahead and picked up a XTI 1000 for $250. Manufactured date is Aug 2008, and the owner claimed it was only used a couple times. Skeptical as I am, I tend to believe him, as there's no smoke smell and the fan is pristine. No rack rash, either.
Hoping the 2008 date is after the issues were cleared up. Had some issues hooking it up to the Mac last night, so I wasn't able to pull the firmware rev.
I think I'm going to stick with the XTI series and pony up the cash for a 4000 once I have the DRs and T48s completed sometime in 2010. The weight on these things is *wonderful*. Can't believe my mixer is heavier than my amp now.
Bobby Shively
Are you running windows on your Mac? I had to borrow Grandma's vista laptop to setup the XTi I borrowed, because I only have the Apple OS. It was a breeze once I downloaded the software.
BASS: Combo Amp & Titan39
For that price I'd get a Crown I-Tech.WiSounds wrote:Take a look at the Ashly stuff too, the PE series amps.
http://www.ashly.com/pe-series.html
4 DR250s
4 Tuba36s @ 30" wide
2 ATs
4 DR250s
2 ATs
The new Peavy IPR amps almost sound too good to be true.
There is a video on sweetwater http://www.sweetwater.com/store/detail/IPR6000/
They are tossing an amp around like a shoe box
Seems like a no brainer if they are reliable, sound good and that light. Especially at that price point!
I guess time will tell
4xT30(24", 4012HO loaded)
1xAT
1xAT
Yep, Parallels. It detects that I connect the XTi, but it never shows up in the Architect software.Gauss wrote:Are you running windows on your Mac? I had to borrow Grandma's vista laptop to setup the XTi I borrowed, because I only have the Apple OS. It was a breeze once I downloaded the software.
I just used my DJ laptop instead, which is XP. It's working fine, but now I just don't know what to set
Bobby Shively
