Do drivers need to be broken in?
Moderator: Bill Fitzmaurice
#1 Post by Bill Fitzmaurice »
The answer is yes. Read below:
https://www.gr-research.com/driver-burn-in.html
https://www.gr-research.com/burn-in-myths.html
You can let drivers break in by just using them, eventually they'll get there. In those plans where driver break in is specified it's so the speaker will work as well as it can the first time you fire it up, and because the break in process will weed out the occasional defective driver.
