This Ashly NE Processor is so sick...
gdougherty
Re: This Ashly NE Processor is so sick...
Fairly nice, but what's the reasoning on the amps? I guess I see no reason to haul ~50lb amps these days. You have ~200lbs worth of amps in your setup. XTi's or PLX's would do the same with less than half the weight. I like the Ashley gear, but I'm a little disappointed to see the digital being an add-on input option.
There local for repairs if needed, I have 2 FET 500's for monitors never have seen the repair shop in over 15 yearsgdougherty wrote:Fairly nice, but what's the reasoning on the amps? I guess I see no reason to haul ~50lb amps these days. You have ~200lbs worth of amps in your setup. XTi's or PLX's would do the same with less than half the weight. I like the Ashley gear, but I'm a little disappointed to see the digital being an add-on input option.
Also use there compressors
4 x T48 24.5" 3015LF
8 x 112 Otops
NEXT 2 x DR280's
8 x 112 Otops
NEXT 2 x DR280's
