limiter setting help
soundxtreme
#1 Post by soundxtreme »
this question may have been asked many times but i have searched and cannot find a thread that answers my question. i have 4-t30's loaded with delta 12lf being powered by cerwin vega 2800. its rated @ 900 watts @ 4ohm. im running 2-t30's on each channel. i want to set the limiter on my driverack px to protect my woofers but i also want to acheive maximum output. the delta 12lf has 35volt max. does the voltage stay at 35 even when running two cabs per channel?
thijs666
Re: limiter setting help
#2 Post by thijs666 »
soundxtreme wrote:the delta 12lf has 35volt max. does the voltage stay at 35 even when running two cabs per channel?
If the subs are wired parallel, then yes. Easy, ain't it ? :mrgreen:
(Power per speaker remains P = U²/R; nothing in the formula changes if you add speakers in parallel)
BF cabs built to date:
soundxtreme
#3 Post by soundxtreme »
thijs666, thaks for the info
bitSmasher
#4 Post by bitSmasher »
Have you given the Delta 12lf T30 a good workout yet? Just wondering how they perform, I scored 6 of that driver for real cheap and am procrastinating on the build - some feedback will inspire me.
Scott Brochu
#5 Post by Scott Brochu »
bitSmasher wrote:Have you given the Delta 12lf T30 a good workout yet? Just wondering how they perform, I scored 6 of that driver for real cheap and am procrastinating on the build - some feedback will inspire me.
I got them in my 39's and there fricken awesome! :loler:
Drumming is a way of life.
ME LIKE TO HIT THINGS!
bgavin
#6 Post by bgavin »
I have the 12LF in my T39/24" and it does indeed perform well.
