Newbie avid woodworker neophile at audio equip
barrajoe
#1 Post by barrajoe »
Hi,
I sure hope that I don't ask too many stupid questions. I work for a community center in TX and we are trying to set up a sound system for our large hall (120 w x 100 d x 24 h). Generally, we only set up a 60 x 60 space for seating in the front center of the space, but for weddings and dances we set up tables and seating around the perimeter. I have had suggestions that we use 2 rows of 4 JBL EON 510 powered speakers and that would be it. I have looked at systems for smaller areas ( our church) and we just got 6 EV2082S set up in 2 vert arrays and 2 monster BagEnd subs and 2-2000 watt amps. I obviously do not have that kind of budget, it would take way too many shoestrings to get something like that. Can someone help? I am looking at possibly 4 dr250's and 2 Tuba 24's. Does that sound even close? What kind of power do I need? I have a couple of small amps given to us by TCU in FortWorth. I thought about setting the Dr250's up in a short J and iff I needed more, I could always add.
dB Challenged
Barrajoe
Re: Newbie avid woodworker neophile at audio equip
barrajoe wrote:Hi,
dB Challenged
Barrajoe
You've got your top to sub ratio backwards. With T24s you'd run them 2:1 with DR250s, 1:1 with DR200s. T39s would be better, if you have room for them. DR200s are equivalent to the EV 2082.
barrajoe
#3 Post by barrajoe »
Bill, thanks for the quick reply. I may have jumped the gun and purchased the wrong plans. If I build 4 dr200's or 250's how many t39's should I build? Our venues typically would not have more than 400 -500 people. Larger venues scheduled ( Shnae and Shane) are providing their own equip. How much power will I need to smoothly power this system?
Thanks dB challenged
barrajoe
#4 Post by DJPhatman »
For a balanced sound, 1:1 ratio for either, depending on the width of the subs. I would build as wide as storage/transportation allows, using cardboard mock-ups to determine the space needed. Using a decent quality cross-over and EQ, getting everything balanced and sounding good should be pretty easy.
FWIW, if this is to be a permanent install, go with t48s. They give the most bang-for-buck spent and are still very portable. Stack 2, V-plated, in the corners on either side of the "stage".
RBIngraham
#5 Post by RBIngraham »
DJPhatman wrote:For a balanced sound, 1:1 ratio for either, depending on the width of the subs. I would build as wide as storage/transportation allows, using cardboard mock-ups to determine the space needed. Using a decent quality cross-over and EQ, getting everything balanced and sounding good should be pretty easy.
I'm just nosey.. as I've seen this "V plated" terma few times. What does that mean?
Thanks,
Richard
Richard B. Ingraham
RBI Computers and Audio
www.rbicompaudio.20m.com
Sydney
#6 Post by Sydney »
See the examples in this thread:
http://www.billfitzmaurice.net/phpBB3/v ... ?f=1&t=398
( 5 pics down )
Basically a horn extension
