Check out my new clamps
#1 Post by LelandCrooks »
http://www.adjustableclamp.com/cm-8000.htm
I like em a lot. They're kind of heavy but way better than pipe clamps. Between these and my array of quick grip clamps, I've got a pile.
True Value has them on blowout. If anybody is interested there are quite a few 36" left. $20 each which is less than half price. Let me know and I'll get some and add to the site.
Scott Brochu
Re: Check out my new clamps
#2 Post by Scott Brochu »
I have some of those and I like the reach on them VS the pipe clamps. With Pipe you can't cross one on top of the other. With these in combination with pipe clamps it's a winning situation when you have to glue a side on and square the cab at the same time. :wink:
Good find
Drumming is a way of life.
ME LIKE TO HIT THINGS!
#3 Post by Chris_Allen »
1,000lb load limit! What do you plan to do with all that? :noob:
pwfirst
#4 Post by pwfirst »
You can never have enough clamps! Those look sweat. Phil
DR 250's #2
T39's 14 in with 102 #2
#5 Post by Tom Smit »
pwfirst wrote: Those look sweat.
:?: :?: :loler: :loler:
Tom
#6 Post by Tom »
The jaws remain parallel to each other and square to the connecting bar while under pressure. Same as the Bessey cabinet master clamps.
Good stuff.
Build Log
-- Done, in use --
4 - Dr250/2510/Piezo
2 - OmniTop 12
2 - T48/3015LF (22 inches wide)
2 - T48/3015LF (25 inches wide)
4 - Melded array w8
? - Omni 10
