Question concerning horn path length and fc
maxmercy
#1 Post by maxmercy »
Once you have gone below fc, should it still be assumed that the sound source is the horn mouth? For instance, when below fc, should you figure on 6dB drops per distance doubled from the horn mouth, or horn mouth plus horn path length?
Thanks,
JSS
Re: Question concerning horn path length and fc
maxmercy wrote:Once you have gone below fc, should it still be assumed that the sound source is the horn mouth? For instance, when below fc, should you figure on 6dB drops per distance doubled from the horn mouth, or horn mouth plus horn path length?
Thanks,
JSS
The mouth is always the source.
