Since I have 3 bands available on the PEQ I figured I would pre-set those for the DR's to smooth the curve a little prior to using the Auto-EQ. Looking at the SPL chart my thinking is to set up 3 bell curves at roughly 125, 5K, and 10K and then boost/attenuate and play with the Q to smooth the response. (down on the 125 and 10K and up slightly on the 5K)
To confirm and monitor the changes during programming I'll set up in a large outdoor area and use my TrueRTA to dial in the response. My thinking is that once I have the PEQ's dialed for the DR200's I can just let the Auto-EQ do it's thing at the various venues.
So how's my logic on this...am I headed in the right direction?
This is unless of course someone already has some settings for the DR200...
