L-Pad question.
vlad335
L-Pad question.
#1 Post by vlad335 »
I want to add L-pads between the mid and high freq drivers in my O12 and was all set to get started until something occured to me. The polarity of the tweeter is reversed in my cab and I am not sure how to wire up. Do I keep the polarity the same going into the L-pad (+ to +) then reverse it after the L-pad to the driver or the other way around? Reverse the polarity right after the passive xover?
Currently running:
Four Titan 48's, Six Omnitop 12's, Two Wedgehorn 10's, Omni12 2-10
Also Built: Omni15 Tallboy, Omni10.5.
'The hardest material on earth is the human skull'. How do we know this? Try pounding a new idea into one.
Re: L-Pad question.
Just insert the LPad into the circuit between the crossover and the tweeter. LPads don't have polarity. They have a signal and ground, but the polarity of that signal and ground matters not.
