A Good Day in the Shop - Melded Array Jigs
I was apprehensive about tackling melded arrays, but these jigs actually make it fun. This is my take on the cutting jig.
And the glue-up jig
And the result
(Edited to replace stale image links)
And the glue-up jig
And the result
Re: A Good Day in the Shop - Melded Array Jigs
DaveK wrote:I was apprehensive about tackling melded arrays, but these jigs actually make it fun.
You just haven't cut enough of these things yet.
Dave, I just started making jigs for piezo's and other small stuff this morning. Nothing as elegant and practical as what you're showing. Please post any new jigs one day earlier from now on
bgavin
Yeah, but he is just about finished with a whole herd of T36... I dunno which is more the PIA...LelandCrooks wrote:You just haven't cut enough of these things yet.
The fun is seeing the jigs work properly. The actual building is just work.
DR brace cutting jig. The jury is still out on this one. I snapped a router bit on the second cut and haven't gotten to the store yet for a replacement.Please post any new jigs one day earlier from now on![]()
Get a 1/4" spiral downcut. I use a similar rig on DR braces and it's slicker than snake snot.DaveK wrote:DR brace cutting jig. The jury is still out on this one. I snapped a router bit on the second cut and haven't gotten to the store yet for a replacement.Please post any new jigs one day earlier from now on![]()
The bit I broke was a spiral upcut. Does up vs. down matter for this application? Also, is the feed direction the same for both? I think it broke because I was cutting in the wrong direction and the bit grabbed. I was moving the router counter-clockwise across the work.
Yes.DaveK wrote: Also, is the feed direction the same for both?
An upcut bit would normally be used when the router is upside down, eg. when using a router table. The idea is to exhaust the chips away from your face and work. I like to use 1/2 shank router bits, a lot beefier.
bgavin
Interesting.
I'm using upspirals on my Jasper Jig to cut baffle holes. My line of thinking was removing the cuttings from the work as I progress around the circle. I make about 3 passes and increase the plunge depth at each pass, to avoid stressing the bit. My router takes 1/2" shank bits (expensive) but they are much less likely to break.
I use an up cup bit, mostly because I can't find my down cut bit.bgavin wrote: My line of thinking was removing the cuttings from the work as I progress around the circle. I make about 3 passes and increase the plunge depth at each pass, to avoid stressing the bit.
bgavin
Bill suggested I use the spiral cutting bits.. very good advice indeed. Makes my baffle and general cutting chores a LOT easier.
Downcut if you're making one pass, upcut if not. I don't even bother purchasing downcut for that reason.
1/2" shank bits help stop the shank from breaking, but a 1/4" cutting diameter is 1/4" cutting diameter regardless of the shank size. Almost every time I've broken a bit it's been the cutter. Which is why I make cuts in a couple of passes, hence, no downcut bits.
I just cut the DR200 butt cheeks, both panels together (BB), in one pass with a spiral upcut. 1/2" shank and cutter.
- SoundInMotionDJ
Whoever posted several months ago with the suggestion to put some of the offcuts from the piezos in the ABS cement - that is awesome!!! I just finished two crossfiring melded arrays and the matching cement makes them look a lot better than the first batch I did.DaveK wrote:And the result
--Stan Graves
10 T39S + 10 DR200 + 1 T48
I always make that cut with the same diameter bit as the material being installed. Example: The butt cheeks are made of 1/8" ply, so a 1/8" bit is used for the cut. That ensures an exact fit when installing the top and bottom extension pieces on the back of the cheeks because you're replacing the same amount of material as was removed.wb2 wrote:I just cut the DR200 butt cheeks, both panels together (BB), in one pass with a spiral upcut. 1/2" shank and cutter.
When you think about it, you have a radius on the panel of 4-11/16". You add 1/8" material to the entire radius, making it 1/4" wider on the outside dimension side to side, or 4-13/16". But, the cut-out area on the extension piece is a full 5-11/16" wide due to the bit diameter. In other words, the convex radius of your cut is 4-11/16", and the concave radius is 5-3/16".
Also, note that the cut is well shy of where the butt cheek panels will meet. That needs to be cut out with a jigsaw. After installing the extension piece, it'll need to be filled. Using a 1/8" bit eliminates that.
