hclague wrote:
I second Harley's request for a Picture of the Roto zip Radius Jig.
Hal
I'd like to see Bill's too. I am sure it will be prettier than mine!
My photos are not too good, but here's the one that I adapted (taken with my phone). I had a trammel arm of the "turnlock" variety for my router ($15 on sale at Sears). I made this really ugly adapter for my el-cheapo spiral cutter saw ($20 at Harbor Freight).
http://www.frappr.com/?a=viewphoto&id=1 ... myphotos=1
With practice it is working reasonably well, but it took practice to get it to work well. Starts and stops were hard to get it to cut to the right place...and not farther or to jump. I practice pretty much all my cuts at least once or twice on wood I don't care about before going in for the real thing. Two other things I have learned (as usual, the hard way).
One is to make sure that the jig is Always flat on the workpiece. If I take my hand off of it, it iwll jump. I have to always be applying a small amount of downward pressure on the tool/jig for it to remain steady. My heavy 3hp router doesn't need this, but this little lightweight tool jumps around without a hand on it.
2nd is to always cut the arc in the same direction that the tool spins. My tool spins clockwise, so my cuts have have to be clockwise too. Don't even try it the other way. At best it cuts like a drunken sailor. At worst it could jump up and really become dangerous.
If I were designing one of these, I'd put a "deadman switch" into it, so that if you release your grip it would cease to run. Mine doesn't have one of these, and it is so small and light that it is tempting to treat it as though it were not dangerous. The combination of smallness, lightness and great torque, however, means that it can jump surprisingly, so you really have to be careful.
