I made simple jig for making dados with my hand-held router.
I figured that I wanted my dadoes to be about 6" from the edge of the panel for a 20" wide T39. To make the guide, I cut a 3.5" strip of 1/4" masonite. Along one edge of the masonite strip I attached a 3/4" strip of 1/2" MDF. Here's a pic:
http://www.frappr.com/?a=viewphoto&id=1 ... id=3808628
To cut the dado, I clamp the guide "upsidedown" with the MDF strip snug against the edge of the workpiece. I then run the router along the edge of the guide. I reverse the workpiece to do the other side. (I found out the hard way that it's best to always have the guide on the left side of the router relative to the router's forward motion.)
Here's a pic of the router cutting a dado with the guideboard clamped to the workpiece:
http://www.frappr.com/?a=viewphoto&id=1 ... id=3808629
This is about as fast and easy a way to cut the dados with a hand-held router as I could think of.
Dadoing noobster style
Re: Dadoing noobster style
Is the wicker object in the background a hat, a lamp shade, or some part of a speaker enclosure?fender3x wrote:...
Enquiring minds wants to know!
Take Care,
David Baldock
It's a melon protector. I work in the backyard in the sub-tropics. When we are not having intense rain, we have intense sun--and that's the time I can work. It's not bad now...but in the summer...let's just say I don't have any trouble getting my PL to set. Plenty of heat, humidity and sweat.dbaldock wrote: http://www.frappr.com/?a=viewphoto&id=1 ... id=3808629
Is the wicker object in the background a hat, a lamp shade, or some part of a speaker enclosure?![]()
Hi Guys,
I know this is fairly old post. As a result the picture showing the jig is no longer there (or at least, the link doesn't work).
Does anyone have a picture showing this?
Thanks
Gary
Thanks
Gary
Gary
4 each T24s w BP102s'
4 each Jack 10s
4 each Jack 10s
