1 inch thick urethane building insulation foam
Jim Van Streader
Anybody know where to get it? Just wasted 10 bucks in gas to find out Home DePoo doesn’t carry it. Wasn’t someone mixing it in a bowl?
JVS Audio Mfg.
National artists through my builds so far:
Days of the New
Y & T
Great White
Tantric
Agent Orange
F4
Blind Melon
Bullet Boys
Quiet Riot
Vains of Jenna
Steelheart
Warner Drive
Gilby Clarke
Dokken
Days of the New
Y & T
Great White
Tantric
Agent Orange
F4
Blind Melon
Bullet Boys
Quiet Riot
Vains of Jenna
Steelheart
Warner Drive
Gilby Clarke
Dokken
Re: 1 inch thick urethane building insulation foam
You could try canned PU foam, apply it into a box of some sorts to force the blurb into some kind of shape. Be aware that larger blurbs need more time to fully cure (the inside could still be soft), and I'm afraid the blurb might not be of consistent structure. Don't use a heat gun to speed up the process. I know of someone who tried. He learned from experience. What he learned was that fumes in the box are rather flammableJim Van Streader wrote:Wasn’t someone mixing it in a bowl?
I still think you'd be better off with some insulation plate material. You could phone some builders? No idea what you would call anyone specialised in making and renovating roofs, but that's what I would try first.
Call other lumberyards. Hard to believe they don't have it, especially in the Southwest, as the aluminum foil outer layers are very effective against heat gain in direct sun.Jim Van Streader wrote:Anybody know where to get it? Just wasted 10 bucks in gas to find out Home DePoo doesn’t carry it. Wasn’t someone mixing it in a bowl?
Jim, if you're buying it for throat fillers you'd be much further ahead to get them pre-formed from Leland.
- Paul Norman
A+ Tim. If you consider the time involved in making them it's much cheaper to buy them from Leland. The person he has making them for him does a really nice job.Tim A wrote:Jim, if you're buying it for throat fillers you'd be much further ahead to get them pre-formed from Leland.
Yeah, sorry, that wasn't meant to be an advertisement, just good advice. It's not worth the trouble to make the things yourself, or the mess!Paul Norman wrote:A+ Tim. If you consider the time involved in making them it's much cheaper to buy them from Leland. The person he has making them for him does a really nice job.Tim A wrote:Jim, if you're buying it for throat fillers you'd be much further ahead to get them pre-formed from Leland.
Jim Van Streader
Polyisocyanurate - is this the same thing as urathane foam? It has foil on both sides but I don't know if it has the same properties and can be carved into shape. Anyone know about this stuff?
I'm sure I'll order from Leland in the future but I need this last night.
JVS Audio Mfg.
Days of the New
Y & T
Great White
Tantric
Agent Orange
F4
Blind Melon
Bullet Boys
Quiet Riot
Vains of Jenna
Steelheart
Warner Drive
Gilby Clarke
Dokken
Days of the New
Y & T
Great White
Tantric
Agent Orange
F4
Blind Melon
Bullet Boys
Quiet Riot
Vains of Jenna
Steelheart
Warner Drive
Gilby Clarke
Dokken
I think it's a four dollar word versus two dollar word describing the same thing.Jim Van Streader wrote:Polyisocyanurate - is this the same thing as urathane.
Sydney
IT"S urethane - No such thang' as urathane
If you change the a to an e then I agree.
Besides that, my spell-check gives me a red line if I type it.
Important fact: isocyanate when burned, gives off cyanide gas - so don't.
Re: IT"S urethane - No such thang' as urathane
Wow, talk about yer magic smoke!Sydney wrote: Important fact: isocyanate when burned, gives off cyanide gas - so don't.
