Straightening Warped T39 Panels
If I have a panel or 2 (or 3) that I have already cut for my T39 that are curved (warped), can I use the wet cloth and steam iron trick on the concave side to straighten them a bit? Funny, those plywood sheets were straight, but the panels warped once cut from the sheet. Straighter panels would be a lot easier to screw and glue in place. Thanks.
All of the panels are less than straight. If I put one edge of the panel where it should be and square up the edge, the other end may deviate as much as a quarter inch from where it should land. So you think it best to try to pull them straight as it goes together? This plywood is pretty stiff - it might take a bit of force.
gdougherty
+1 As long as all the cut edges were straight, the horn path will square up the driver end of the cab and the sides will come into square as well when you assemble them. That's why you measure the bracing up against the side, a few screws or some pressure and brads will tack it all together. Make sure all the path corners are straight from side to side and it all works out. I had the same sort of deal with my most recent OT12 build. Small warps in the large panels but it all came square upon assembly. Use a large square and just make sure they're in line.Bill Fitzmaurice wrote:If you follow the instructions in the plans and use the guideboard method of jointing it's a non-issue.wespaul wrote:This plywood is pretty stiff - it might take a bit of force.
So how did you fit the driver to the baffle? Without the driver on hand, there is no way to insure that the driver fits the H-nuts or T-nuts, whichever you used. Even with one side off the T39, it is still very very difficult to get them installed correctly.wespaul wrote:I won't have the drivers until late next week, anyway.
BTW, there is even differences between individual drivers. I suggest you fit a driver to a baffle, and use that same driver in that baffle spot.
(edit for spelling)
I haven't put anything together yet except for the top to the side. I am dry-fitting all my parts to see how they fit the lines I traced.DJPhatman wrote:So how did you fit the driver to the baffle? Without the driver on hand, there is no way to insure that the driver fits the H-nuts or T-nuts, whichever you used. Even with one side off the T39, it is still very very difficult to get them installed correctly.wespaul wrote:I won't have the drivers until late next week, anyway.
BTW, there is even differences between individual drivers. I suggest you fir a driver to a baffle, and use that same driver in that baffle spot.
I'll heed your suggestion on mounting the drivers on the side of the baffle I fit them on before jointing the baffle panel in, and thanks for the warning.
Re: Straightening Warped T39 Panels
i know this is an old post but hey. some years ago i made a load of checking fixtures that needed to be flat within 0.004" the ply wasnt too good. the solution was to cut grooves in the ply going through all but the last 1 or 2 laminations cut in both directions of the board about 4-6" apart. the grooves were then filled with epoxy resin and the base screwed on. should work to get badly warped panels flat without having to put anything under stress and using pu instead of epoxy.
