OK.. I've finally had time to dial in my dual T-18, and I think I can wholeheartedly recommend it.
It's finally had some time to break in, and sounds much better, I've found out that I need it closer to my listening position than my mains to eliminate the 'in a can' sound, that you get from the horn time lag.
So, I did a 1hz in room test at my listening position, scosche spl meter, C weighted, 2 meters from sub, 3.5 meters from mains.
Here it is:
20-29hz.
86.4, 85.5, 86, 87, 87.5, 89.2, 91, 92.5, 92.9, 93
30-39hz
93,94,95,97,98,98.5,100,102,103,98
40-49hz
89,93,98,100,100,100,101,101.5,102,101.5
50-59hz
101,101.5,102,103,104,103,100,98.5,97.7,96
60-69hz
94,92,90,87,85.5,89.5,92.4,93.7,93.7,93
70-79hz
92.5,92.2,92.2,91.7,90.8,89.7,86.2,80.1,62.2,78.7
80-89hz
80,82,86,87.4,86.5,85.2,84.6,84.9,84.1,84
90-99hz
79,79.5,84,87.7,90,91.5,92.5,93.5,95,96
100-110hz
96,96.1,95.9,95.2,94,92.5,90,89,88,89
110-120hz
89,88.7,88.3,86.6,84,85.2,86,86,85,84.3
Don't you just LOVE acoustics.. I've seen rooms that have 36db swings... yea, I know I have a dip at 40&80 in this particular spot, 1' away, it's a different story, so I'm not too concerned with it. My living room is 17x29x9... just for that reason. NO ACOUSTIC material is in the room.
So, in the end of the day, can a dual driver T18 get loud and sound ok in room -- yes is the answer.
It has real output from 30hz on up. Just cross it low, about 40hz is just about exactly right on the money. (funny... I remember bill said 40-50hz was about right on the money in the plans....)
EDIT:
After thinking about it for awhile, I came up with a way to tame the 55hz spike, without killing 80hz. I added a simple 16mh (or may be 18, couldn't read the writing real well) choke I had in my stash of stuff, and then moved the cross back up to a typical 80hz.
The green line tells the story -- MUCH better. and the 1meter response doesn't show the 40hz dip, that my coffee table location showed. In fact it was the opposite... 114db.. most likely a floor to ceiling resonance due to the cabinet facing straight up, which is why I'm +6 and 1meter and -6 at 2meters. It's less than a db variation from 50-130. (I only did every 10hz, not every 1hz on this test)
The night and day difference the choke made makes me think that any one with a T18 would benefit, not just me with a 24" cabinet and dual drivers.
This is no joke, I turned it up a little and clocked it at 126 @40hz... My meter only goes to 130, so I stopped there. BTW -- it's being powered by ONLY a nht 120watt amp... My feelings about this sub have turned 180degrees after adding the 6db/oct choke....
