[ Moved from http://billfitzmaurice.com/phpBB2/viewt ... 6319#46319 ]
Short of manually using the Ohmmeter, how do you test XLR cables?
I have a quite a few broken or suspect cables that need some work, and I'm thinking about whipping up a simple tester, or buying something inexpensive.
You guys are a great source of experience and wisdom. Any ideas from the group are appreciated.
I looked at [Behringer CT-100] - the price is right. Both ends need to be at the tester, unless I run a working mic cable from the tester.
I see some that look interesting:
http://ratsniffer.com/
http://www.markertek.com/Product.asp?ba ... rch=0&off=
I'm hoping that a well-known, widely used cable testing soution will surface from this post.
XLR Cable tester recommendation?
Sydney
Sounds like you want a trace device ( like fox and hound sort of thing )
B& H video has a bunch with different capabilities ( I can't make a recommendation )
http://www.bhphotovideo.com/bnh/control ... &Q=*&bhs=t
- DAVID_L_PERRY
I have the behringer cable tester and it works as advertised...
I used it extensively to test my 24/8 multicore after cutting it and fitting Edac Multipin connector for the desk end (cutting a brand new 30m 32 way multicore and hoping you can solder it all back up again takes some balls...
It was worth every penny......and its not a lot of penny's..in fact it costs less than a single XLR lead..!!
Dave
Dave
If you're looking for a 2-piece cable tester (so both ends of the cable don't have to be together), you might check into a Test-Um unit. They use TDR to indicate cable length so you can identify how far along the cable a break might be (after you've configured it for the cable capacitance). You'll need to build a couple of XLR-to-RJ45 adapters to connect it.
Take Care,
David Baldock
Take Care,
David Baldock
This one (even though it says 'Nady' on it) looks interesting. I like the fact that it does Speakon, XLR, and 1/4". Inexpensive and simple enough that I doubt even Nady could screw it up...
http://www.musiciansfriend.com/product/ ... sku=338003
gzc_stageTech
- Paul Norman
The unit I use to check XLR cords is called The Rat. www.audiocontrolindustrial.com-ph425-775-8461. It has a send unit you plug in one end and a sniffer unit you plug into the other end. Three lights on the sniffer end to show continuity.
I've been using the Behringer for a couple of years now,I like the tone generator that's built in also. Helps track down any line problem alsoDAVID_L_PERRY wrote:I have the behringer cable tester and it works as advertised...
I used it extensively to test my 24/8 multicore after cutting it and fitting Edac Multipin connector for the desk end (cutting a brand new 30m 32 way multicore and hoping you can solder it all back up again takes some balls...)
Dave
4 x T48 24.5" 3015LF
8 x 112 Otops
NEXT 2 x DR280's
8 x 112 Otops
NEXT 2 x DR280's
- mloretitsch
