Here is a shot of my studio monitor set up using pink noise and a dbx rta mic held just a foot away from one of the monitors.
As you can see, the 'multi~inspector' is flat where as 'live's' spectrum' analyser has a decline. This is because the multi inspector has a default 3db/oct boost for Slope and live's analyser does not.
My question is, when calibrating the eq on a pa system outdoors (or indoors) should you have the 3db/oct boost engaged or not to get a reading ? It seems to make sense to me to use it on when trying to achieve a fairly flat response such as what my monitors show with it on otherwise the sound would be top heavy ?
