Titan 48 SPL Charts/Comparisons
Locked
#1 Post by Bill Fitzmaurice »
These charts compare a 24 inch wide T48 (two where noted) loaded with an Eminence 3015LF driver with various subs of similar size, or larger, both manufactured and DIY. Charts are 2.83v/1m.
Peavey SP 118
BassMaxx Z5
LabSub (compared with two T48)
JBL SRX 728.
With its nominal 10 ohms impedance 2.83v into a T48 is 0.8 watts. The same voltage into the 4 ohm SRX 728 is 2 watts.
Danley Labs TH115
Cerwin-Vega L36
A 27 inch wide 2x12 3012LF loaded T48 and the $4,600 Turbosound TSW218, a 2x18 loaded folded horn.
As cabs are added frequency response flattens. This is a stack of eight T48:
[/b]
Last edited by Bill Fitzmaurice on Sat Sep 22, 2007 10:56 am, edited 10 times in total.
Locked
