Radial Arm Saw
Radial Arm Saw
Would a radial arm saw be good for cutting the angles on the ends of the boards as opposed to a table saw. I am inheriting one from my father and need to decide if I should get it set up to use in my BFM projects.
It'd be great, I use mine a lot. Some of the weird angles, 50+ and 60+ degrees are easy cuts on a RAS.
BUT!!!!!
Take the time to learn to use it SAFELY. They can be dangerous to a newbie, moreso than other saws. Safety, safety, safety. Get clamps, lots of them. Clamp your work down. Keep your hands well away from the blade. When a RAS grabs it has a tendency to run at you. Anything in the way is going to get chopped off.
Make your first cuts on narrow scraps to get the feel, then try something a little wider. You'll notice the saw wants to push toward you due to the rotation angle. Keep that in mind always.
BUT!!!!!
- Frankenspeakers
What Tim said... RAS demands respect, but they are the most useful kind if saw that I know of.
Yes... they are wonderful tools... test some cuts on scrap... watch how it "grabs" the wood... he is absolutely correct about clamps everywhere...
Check this idea out... http://benchnotes.com/Radial%20Arm%20Ta ... table.html
Make sure your blades are sharp too. Either sharpen or get a new blade. It's important with all circular cutting saws, but probably more so with a radial since it will run at you if it grabs. Sharp blades will give you cleaner cuts and leave less burn marks on your cut edges as well. Good all around.
