Speaker holes
Speaker holes
What does everyone prefer for cutting the driver holes? If I use a jig saw do I need a expensive one to do the job right? I see the Jasper hole cutting thingie on parstexpress, is this worth getting?
Re: Speaker holes
You can easily get by with a cheap one, but I just upgraded to the Bosch one that everyone recommends and it's like a totally different tool than my old cheap B&D jigsaw.rec wrote:What does everyone prefer for cutting the driver holes? If I use a jig saw do I need a expensive one to do the job right? I see the Jasper hole cutting thingie on parstexpress, is this worth getting?
The Jasper hole jigs are designed for use with routers (obviously) and are supposed to be quite good for cutting holes. Honestly though you're fine with careful application of a jigsaw imho.
1590EVSKrec wrote:do you have the Bosch model #
Amazon link: http://www.amazon.com/Bosch-1590EVSK-6- ... B0001X21RG
My dad's a pro contractor, he says that it's the only jigsaw any contractors he knows will use, and now that I own one I can totally see why.
Also comes in a barrel grip model if you don't like the top-handle.
- SoundInMotionDJ
Re: Speaker holes
The jasper jig is nice.rec wrote:What does everyone prefer for cutting the driver holes? If I use a jig saw do I need a expensive one to do the job right? I see the Jasper hole cutting thingie on parstexpress, is this worth getting?
I use a piece of scrap 1/4" ply that I attached to the router base. I drill 1/8" holes a the diameter I need...then mark them with both the radius and the purpose (i.e. D=9-1/8" BP102 Spacer ID). I add more center holes as I need them.
The current template has center marks for the BP102 spacer, the support ribs and butt cheeks and horn throat for a DR200 and DR250, and several more.
Precision is one thing, repeatability is another. I'm sure that the Jasper jig could make a more precise 4-9/16" radius hole. But my jig has almost prefect repeatability - without having to think about it. I go to the hole that is marked for what I'm cutting. And that means that even if my holes are off by a little from the plans, they will make up for it by being the same for every box I make.
--Stan Graves
10 T39S + 10 DR200 + 1 T48
- DAVID_L_PERRY
I made this for my circular cuts:
http://billfitzmaurice.com/phpBB2/viewtopic.php?t=3714
It is not repeatable like Stan's template, but then again it is easy to set up for any size holes that I need.
The cadillac.klocwerk wrote:1590EVSKrec wrote:do you have the Bosch model #
I had (still do) one, it broke, so I bought a PorterCable on a closeout for $50, about a $200 jigsaw. Mistake. Should have fixed the Bosch. It's a far superior saw.
I used the jigsaw for most of my speaker holes.
And one day I set up the plunge router with a radius arm.
Man, it is quicker to set up; quicker to centre and you get a perfect round hole.
I'll never go back to a jigsaw.
What also made me go to a jigsaw was that when cutting a circle with a jig saw, the blade had a tendency to bend, causing the edge to be not perpendicular to the faces.
Robert
Robert
