So let's say that I need a panel that is longer than the a can cut out of my available wood supply. Lets say that I need a 24x48 rear panel. I am wondering if I used 2 24x24 panels with the seam going horizontally, with the seam also being supported by a 4"x.5" brace on the inside of the box would be a solution? I could even miter the two "seam" edges of the boards if that would help. I would also be bracing the back at the recommended locations in the plans (O15). I would fill the crack and sand it down before finishing as well.
Is this OK?
Wes
_______ _______
______/ /_______
4"W !______!
Janel Joining (different than in plans)
