sawing by hand?
sawing by hand?
has anyone actually done an omni 10 by hand?
the only parts that i cant figure out how to do would be the 30 and 60degree angles...
any tips for doing those cuts?
Strapping Young Stu
Re: sawing by hand?
Are you sure you want to even attempt such a thing? I think you might be able to make an O10 with only a jigsaw...and you can get a pretty decent Chinese copy of a Makita or Bosch jigsaw for about $20 at Harbor Freight or Northern Tools. Wouldn't you rather do that?
That said, if you got a couple of steel or alu rails that are about 4.5' long, and spaced them just wide enough apart to fit the blade you might be able to make the streight cuts clean enough for PL to do the rest of the work. Not sure how you'd do the circle cut for the baffle.
It seems likely that if you try this I will lose my title as the worlds slowest BFM builder...
Re: sawing by hand?
Details how to do so are in the plans.diechris wrote:has anyone actually done an omni 10 by hand?
Marko Ursin
- Harley
I dunno, you could always get your War Office in the saw-pit underneath for the push-pull.Bill Fitzmaurice wrote:Circular saw. A handsaw is taking things just a bit too far.wannabe wrote:Hand circular saw or an actual hand saw (like push-pull lumberjack type)?
That way she'd be glad to advise you to get get a benchsaw with her blessing after an hour or so of it.
