Auraco plywood at lowes
brodave2
#1 Post by brodave2 »
Seems to be some pretty good stuff, but! If you cut narrow strips of it they will warp. Curl up almost like a pretzel. I still think it's one of the best bargains in plywood, but be aware. I know some of the designs use narrow strips of plywood for various things. It curls up.
It won't be a problem if you don't cut it before you use it. Once assembled it's fine. It also helps not to be in a high humidity environment, but in your case low humidity is only about six or seven days a year.
Last edited by Bill Fitzmaurice on Wed Jul 04, 2007 9:19 pm, edited 1 time in total.
horst
Re: Auraco plywood at lowes
#3 Post by horst »
brodave2 wrote:Seems to be some pretty good stuff, but! If you cut narrow strips of it they will warp. Curl up almost like a pretzel. I still think it's one of the best bargains in plywood, but be aware. I know some of the designs use narrow strips of plywood for various things. It curls up.
with 5-ply???? sounds like an unlucky batch
brodave2
#4 Post by brodave2 »
low humidity in Houston is 50%. I'm going to rip some solid pine for the thin strips, piezo bank mounts and such.
brodave2
auraco
#5 Post by brodave2 »
I have some of the stuff that has been out in the weather for about a year with no paint and no protection and it hasn't delaminated.
