EQ Down for Flat Response
bgavin
#1 Post by bgavin »
I have always been told to EQ down for flat response, rather than boost.
Using the T48/DR280 as an example, I would pull down (cut) my sliders to bring everything to Flat in relation to 40 Hz.
Right or wrong?
Wrong, as least as far as analog EQs go. Analog EQs have a lot of bandwidth overlap, and the higher the peak or lower the notch the more overlap there is between adjacent bands. To minimize this you want to cut and boost pretty much equally with respect to 0 dB. It's not as critical with digital EQs, which have far higher Qs than analog so less overlap, if any, but still a good idea. The main reason for the old 'cut only' adage was to maximize S/N, but with low noise circuits that's not much of a concern.
bgavin
#3 Post by bgavin »
Using two T48 as an example, they are flat at 112 SPL from 65 Hz, and drop to 100 SPL at 30 Hz.
The midpoint is 106 SPL, so I would boost the lower and cut the upper to get to 106 SPL as Flat?
I have interpolating EQ boxes.
#4 Post by Bill Fitzmaurice »
bgavin wrote:Using two T48 as an example, they are flat at 112 SPL from 65 Hz, and drop to 100 SPL at 30 Hz.
That's how I'd do it.
pedro
#5 Post by pedro »
(Pedro reads, scratches head, and realizes he's years away from being ready to participate in this discussion.)
Strapping Young Stu
#6 Post by Strapping Young Stu »
Pedro take a graphic EQ from a bass right its gonna look like this
Notice how all the sliders are centered around the midpoint, so the frequencies that are louder, should be cut, and the frequencies that are quieter should be boosted like so
In the old days we were taught to cut ONLY so you would only take the louder frequencies and the frequencies that were middling in volume and take them down so that they were the level of the lowest volume frequencies, nowadays we dont need to do that anymore because technology has improved.
Stu
hclague
#7 Post by hclague »
Be careful boosting eq frequencies. You may be trying to correct an "un equalizable event" i.e. cancellation due to reflection.
Hal
pedro
#8 Post by pedro »
Stu that second EQ produces the dreaded smirk face. When I did have eq sliders I tended to have them straight or perhaps in a slight frown. Not sure what I was cutting or boosting but that seemed to sound best to me.
Ron K
#9 Post by Ron K »
I've always EQ'd around center. Up where needed and down where needed.The only place I was more inclined to use cut at a greater rate than boost was with monitors. Bear in mind with a poorly designed monitor boost and cut will be necessary. With a proper designed one we would generally hit the Strips first for tone then the graphs for smoothing keeping the amount of cut or boost to an absolute minimum. Mains require a bit different approach.
Generally eq using noise or sine wave tones to gain flat response in the room. Then move the mic location to different locations and find the best compromise between boost and cut to flatten out the system at the most points in the room or even outside. Often this leads to repositioning stacks until you get acceptable coverage in most of the room. It's also time consuming! After getting a plot down we would put the curve into memory and script the set-up on a laptop using Word. I carry stage plots and room layout sheets so I can keep track of the set-ups. This helps minimize load-in to live time dramatically and keeps your shows running smooth.
