Tips for spraying Duratex?
Mark Coward
I'm interested to hear any tips/advice on spraying Duratex. I remember some old posts, did a search and couldn't find them now. I just popped the cherry on my new Harbor Freight hopper gun, things are working ok just wondering what other tricks I might learn.....do you thin it with water, how to use the resin sand texture additive?
Mark Coward
I used to thin the first coat, but with the newest formulation that's not required. Do the first coat with a fine nozzle for color, then go to successively coarser nozzles for more spatter. If you use the beads just mix them in as recommended and spray. Beads are especially nice to hide grain with softwoods, not really necessary for that with birch unless you wan a non-skid finish.
Mark Coward
I just figured that out the hard way, I thought I remembered Bruce saying he thinned with water. I tried it, just a little water maybe 10/1 at most, and made it really runny. Also, make sure the nozzle is attached before you fill the hopper with paint .... I now have a nice big blob of duratex on my patioBill Fitzmaurice wrote:I used to thin the first coat, but with the newest formulation that's not required.
Mark Coward
bgavin
Not me. I have not applied Duratex yet. I picked up the gun for a good price, but am concerned about a huge mess from overspray, and what I have to install as a paint booth to shoot outdoors. We are in the ferocious heat season now, so I'd have to shoot before 0800 to avoid the heat.
I've learned to apply carpet in a professional manner, so that will suffice for the moment. It is VERY time consuming.
At most the drift from overspray is a foot or two. I spray outside most of the time. This winter I made a very primitive booth from scaffold and .99 drop cloths. As far as fogging or a respirator they're unnecessary. It's not at all like spraying paint. Very much like shooting drywall mud, just less messy.
Don't be.bgavin wrote: am concerned about a huge mess from overspray,
Like Leland, says, or one of those cheap resuable blue poly tarps. That's what I use. In fact, last time I put the tarp over the picnic table, set the cabs on it and sprayed out in the yard with no backstop or makeshift booth of any kind.bgavin wrote:and what I have to install as a paint booth to shoot outdoors.
I wouldn't worry about it. Duratex even recommends hot dry weather, and more heat for faster curing. It doesn't 'flow out' like paint, quite the opposite.bgavin wrote:We are in the ferocious heat season now, so I'd have to shoot before 0800 to avoid the heat.[
Get some Duratex and a piece of scrap plywood and try it. It's not as technical as it sounds.
Mark Coward
One thing I meant to ask, with the Harbor Freight gun there is some air blowing out all the time......it seems to work ok, but is this normal? I've not used a hopper gun before, and the manual doesn't say anything about that. The manual does say to remove the "cup" and turn it upside down and fill from the small end, which is obviously wrong as the hopper only has a half lid, lol
Mark Coward
What sucks is I'm going to have to figure out a place to do this in the winter. My work area in the basement is so small I'm not sure I could spray down there at all. Winter builds may be limited to carpet, or a free black latex paint finish to get them through until spring when I can spray outside.
The first cabinet I sprayed was in the garage, and the one thing I noticed was a lack of light. If I ever spray in there again, I'm going to set up my par cans on the towers so I can see what I'm doing.
Minus the gels, of course!
bgavin
I have nowhere to build during the winter at all. They don't speak Basement in Kaleeforneeah. I sure do miss the old house in Colorado Springs... 4 car garage, full basement, two story. We got 1200 square feet here for the same money.
