Cutting PVC
DJ Big Ronn
Cutting PVC
I just thought that I would share a good way to cut pvc. I cut a 2 by 6 the approximate length of the pipe I'm cutting and clamp each end of the pipe and board together. It makes a stable platform so that the pipe doesn't roll and you can rip it with a saw. You'll have to put it across the corner of the work bench so that the clamps dont hit.
