2 corner loaded T-39's
Last weekend (using a signal generator) I was able to determine one of my 2 t39's was leaking air out the access panel. I fixed this problem and also Plast-coated(you can get a can a Walmart for $40) the cabs. Today it is raining and I have nothing better to do so I corner loaded the T39's in my garage, set up my array mains hit play and WOW!! The combination of fixing the leak and the corner loading is remarkable.
The bottom end is simply amazing, the bass is imediate, punchy,in your face and oh so loud!! I should also mention the T39's are loaded with the 10" MCM driver(cheap!!!!!!!) I can't imagine how it can sound better, even with a higher priced driver. With less than 150 watts into each cab, it is just incredible. Bill this is truly a great design and for bands on a TIGHT(non-existant) budget it is truly a great service to bands that do thier homework. Thanks again and I will be ordering plans for the DR250 this summer when time permits.
