Hello member
I just build a pair of jack 10 how do I wire this plate amp to the crossover from speaker hardware ? . According to Mr: Bill (4 pole Speakon on the cab containing the amp and one on the extension speaker ) any diagram would Appreciated Thanks
Dayton ppa800 dsp
Re: Dayton ppa800 dsp
It's a 2 channel amp with built in electronic crossover. You don't use a passive crossover.
If you already have the Jacks loaded with the passive crossover, then you'll just use one power section on the amp. Use the low one as the high one has a built-in highpass crossover at 1khz. I'm assuming you are going to put this in a separate box? No way it's gonna fit in a Jack 10.
Build a box for it and connect the amp output to a jack plate with two paralleled NL2s. Then send one to each Jack via single pair speaker cable. This will be a mono setup and you won't be using the "high" end of the amp. Don't worry, the "low" amp will operate full frequency. It has pretty good DSP in it for setting EQ, high pass, etc.
If you decide to bypass the passive crossovers in the Jacks, then that will be a different wiring setup....not really necessary as the passive crossovers in the Jacks do the job just fine and let you use use single pair cable instead of a 4 wire setup.
I have one of these in my SLA Pro.
I'm not quite understand but will try this tomorrow BTW the plate amp fit perfect at the side of the Jack.
Thanks
Henry
Thanks
Henry
If you don't understand make sure you do understand before proceeding further. If you make a mistake the penalty can be blown drivers.
Are you going to attach a box to the outside of the Jack to hold the amp? I don't see any way you could fit that inside the cab with the Horn braces and the Flanges...and the amp is exactly the same height as the Jack. I squeezed one into a SLA Pro with some modifications to the bracing, but in a Jack10? Can you explain the orientation of how you'd put it in?
Also, are you using these for PA use?
