Duratex over new Plastic enclosure?
I have just come by an small EV speaker but its white! Has anyone used Duratex to cover boxes that are made of for lack of a better word, Plastic? Would you sand and prime to prep or any other suggestions.
IN PROGRESS Jack 10 Lite x2, hopefully 4
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
Re: Duratex over new Plastic enclosure?
I'd do a test on something small first. I'd certainly prime it first and scuffing would be a good idea. May be hard to get it to stick though.
Have you considered doing a wrap instead? A friend of mine has been wrapping guitars and basses successfully. That might be a better alternative than Duratex.
The box is very contoured and irregular so not sure how wrapping would work. Any of the rattle can plastic paint things that might work?
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
+1 on the Fusion spray paint.
It comes textured as well. https://www.lowes.com/pd/Krylon-FUSION- ... 5001057303
himhimself
A weird trick I've had good luck with when painting plastics is to first "paint" the entire surface with purple PVC/CPVC primer, then spray paint over that. I did it on some outdoor lighting fixtures and they've held up over several years.
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
Great ideas gentlemen!! Thanks.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
