I drive a '17 Tundra double cab and discovered, much to my chagrin, that neither an AT nor TrT will fit in the back.
I'll add pitchers of what I'm working with in a bit.
Thoughts?
Yeah, the issue is that there's no behind the seats. The rear seat backs are right up against the back of the cab.Bill Fitzmaurice wrote: ↑Fri Apr 18, 2025 9:22 pm You can try it, but the TruckTuba was designed to fit behind seats.
I just mocked that up with cardboard and the biggest downside to doing this would be the blocking of the view out of the rear passenger window. Would make the already large blind spot worse.Keryn O'Shea wrote: ↑Sat Apr 19, 2025 6:06 am An AT facing up, or down with supports would fit..?
You could strap it to the flipped up seat
hmm...not a bad idea. However, if I'm going to sacrifice a seat for this, I'd rather it be the single on the passenger side.himhimself wrote: ↑Sat Apr 19, 2025 7:21 am If i were you, I'd build some supports the same height as those seat mounts on the floor and use a truck tuba.
This definitely sounded compelling! So I cut out a mockup of the footprint of the TrT and tried fitting it. There would be too much to notch. So much so that almost the entire cab would have to be shortened from 36" to around 32". Ugh. I could rotate the TrT so that it sticks out from under the rear seat, and it would fit, but there goes any leg room anyone sitting back there might have. Drat!himhimself wrote: ↑Sat Apr 19, 2025 7:21 am Or notch out panel 9 and trim back the sides at the mouth to just squeeze it in there between the mounts.
Good to know. Thank you Shawn!shawn_g wrote: ↑Fri May 02, 2025 5:52 am Kind of late to the party here, but years ago I squeezed a T18 in the trunk of my Subaru Legacy (sedan) for the fun of it. It DEFINITELY needed EQ to sound good and I vaguely recall it being very boomy in the upper bass frequencies (60-100hz). It could probably be good with tuning, but it was similar to the budget sealed 12" I normally have in there.
