Hello!
This is my first speaker build and I'm pretty excited about it.
I'm going to build a Simplexx 15 with a tweeter. The speaker will be used as a Bass guitar cabinet, primarily being used in practice space playing classic rock & funk that generally includes drums, electric guitar, and a Rhodes. Every once in a while, it will be used for a small outdoor gig.
I have a question that I could not find directly addressed elsewhere in this forum. I am having a hard time deciding whether to build my cabinet sealed or ported. My question is do I have to make a decision? Can I build a cab that can be played both ported and sealed? I have chosen to use the Eminence BP1525 driver because, at present, I am inclined towards building a sealed cab. That driver is rated for both sealed and ported enclosures. Would it cause any problems to follow the plans to build a ported cab and then fabricate some plugs to obstruct the ports so the cab can be played sealed? I can see it will be harder to plug the ports given they are triangular and not round. I understand the ports would need to be made properly airtight or I would be getting the worst of all worlds.
Has this been done before? Am I barking up the wrong tree?
Thank You!
Simplexx 15 Ported and Sealed?
Re: Simplexx 15 Ported and Sealed?
The plans go over sealed vs ported and what drivers he recommends. (I assume you don't have the plans yet)
santacruznick
Thanks for the reply. I purchased plans for the Simplexx15. Based upon the list of recommended drivers I chose the Eminence BP 1525 as it is the closest one to the qts specifications recommended in the plans for a sealed cabinet build. However, in the process of selecting that driver, I did notice that the BP1525 manufacturer's specifications list the BP1525 as suitable for ported applications. This got me thinking about whether I could build a cab that can be switched from ported to sealed on the fly, perhaps in response to the situation in which the cab is being used. I.e. type of music, venue etc.
- Strange Kevin
If your double check the QTS spec on the BP1526 is should be in the range that's recommended for either a sealed or ported S15 cab.
Ported will give you a little more sensitivity on the low end.
You can check the frequency response graphs here viewtopic.php?t=20963
Since the dimension are the same, I don't see why you couldn't made a second sealed baffle and screw it to the ported baffle. Or just some squares to cover the port. The only difference I see in sealed vs ported is the bracing.
