New HF Driver from Eminence
#1 Post by Bruce Weldy »
Eminence just came out with a new driver. It's the N210T-8
https://eminence.com/collections/1-high ... -neodymium
It looks like it's a good replacement for the old NSD2005 that was discontinued. Specs look about the same and it's got a 2" diaphragm as opposed to the 1.5" on the F151M that has been the replacement for using the 1.2k crossover.
Bill, does it get your blessing?
Re: New HF Driver from Eminence
#2 Post by Bruce Weldy »
And an update on the F151M.....it's still not being built and may not ever be. Because of the issues with it, I'd suggest not even using them if you can find some still in stock somwhere.
#3 Post by Bill Fitzmaurice »
It looks good, but it's expensive. As for the F151M, one alternative is the LaVoce DN10.142.
