Built in Handles for a THT 24" wide
sfraser131
#1 Post by sfraser131 »
Hi, I am about to build a THT 24" wide and was thinking about installing built in handles for ease of movement throughout the house/stairwell etc. Has anyone done this? I assume the handles would need to be well sealed, and avoid short circuiting the transmission path or horn. Any thing else?
thanks
Scott
Re: Built in Handles for a THT 24" wide
#2 Post by Bruce Weldy »
If you use inset handles, you'll have to figure out where you can put 'em so that they don't interfere with the horn panels. So, that would be pretty much at the very top or very bottom if you put 'em on the sides.
You can put spring handles most anywhere if they are surface mount.....but, they will most likely rattle.
