TLAH OR PRO'S FOR THEATER
Posted: Mon Dec 18, 2023 6:53 pm
Working on dialing in our home theater room. Currently I have the following:
This area is a kids area, also have a pool table, bar, but I don't think that really matters. Listening distance varies from time to time because the kids moving stuff to play, forts, etc.
My plans are to use a TLAH or the pro version for my mains, wall mount them higher? (should they be head level, does it matter? Can I mount them on the wall with the tops near the ceiling?
I feel like the room is large, 16'x18' with another room behind it with no wall at all (see pic) that is 14'x23'
Would I benefit from the Pro version?
So really, 32x16 feet pushing 32x 23 in areas
Center I was planning on the SLA Curved array. I planned to mount this above my screen, maybe angle it down toward the listening area (is that needed). Chance I have to put it under screen and point up, need to check the plans for clearance above.
Then I was considering building surrounds to replace the Edifier I have now. I believe that is part of the TLAH plans. I currently have the TLAH, SLA, David and THT plans. I don't mind buying the Pro if they will work better for me.
For power I am a Denon fan, but I have inherited a TON of older but super quality AV equipment. My Wife's aunt/uncle owned an AV company, both have passed on. I have probably 35 commercial amps, from single channel to multi room systems. So if I need more power than my Denon AVR-X3500H can provide I have options.
oh... this is theater/tv only. Upstairs I have a smaller tv, with speakers more designed for music, etc.
Thanks in Advance.
- THT 3636x24, its behind the listening area in a corner
- 120" 4k projector, ceiling mounted
- random speakers for my mains, Polk something for my center, cheap edifier rear surrounds
- all my equipment is in my utility room and speakers were pre-wired when I build my house
- carpet floors, basement with 9 foot ceilings, standard drywall finish
Thanks in Advance.
